What are these implements worth?
/ What are these implements worth? #1
485didriver
Bronze Member
Mississippi near Memphis
Mahindra 485DI
I'm a weekend warrior on the tractor, and don't really do anything except bushhog my place (8.8 acres, all grass, one stinkin' tree). I've about decided to get rid of the tractor since that's what it was bought for, and to just get a 60" pro mower, mainly b/c of the time it takes to cut currently vs. the time it takes my neighbor with his ExMark mower. I'm roughly 3 times as long getting the same thing done.
Anyhow, I have zero idea of how much I should realistically expect to get out of the implements I have, so I thought y'all might be able to help me decide what to ask/take for them:
1) a 6' Grizzly SD (standard duty) brush mower. Has a stump jumper, but also has a couple spots that need welding/repair on the right rear corner. Works fine every time I've used it, though it was getting loud when I used it and rattling a good bit. Turns out that the bolts on the top of the deck needed tightening (who knew?). Now it's fine. Has a few areas of rust on the deck.
2) A 6' Tuffline box blade, Model TB2-72. The kind with the teeth on the front side (7?). It's in good shape, a couple spots of rust on the corners where paint has chipped off, but no issues at all. Looks to be in very good condition.
3) a Curtis brand 6' finishing mower. To be honest, the guy I got the tractor from also sold me all the implements, and this one has never been used at my place. No idea why I never used it, but I literally have never hooked it up and used it. Just been sitting, and was serviced just before I bought it (new belt, etc.). Know nothing more about it.
As you can see, I'm trying to tell every detail, because I want to get a fair assessment of the value for these. So, what do y'all think?
/ What are these implements worth? #2
Are you mowing as often as your neighbor. A 45hp tractor with a 6' mower should be able to fly through the grass. The finish mower might be faster. If your ground is to ruff to go any faster on the tractor it will be 10 times worse on a ZTR.Test one on your property before you buy one.
Bill
The thing that gets me is that it's not rough, but the layout is not rectangular, but irregular. The house sits on the front 1/3, and there's a pasture that kinda takes a "D" shaped bite out of the area behind the house. Throw in the one tree, the barn, my daughter's playset, and there are just enough issues to slow down the whole thing. Pretty smooth ground, except for probably 1/2 acre or so that's always wanting to wash. Might try the finishing mower out, just for grins. Hey, won't cost me anything, will it? :D
/ What are these implements worth? #4
I fully agree with otherposter that you need to demo a ztr on your property for a complete mow before you buy, I did not dothis& amcompletely redoing my 5.8so I can actually gofaster than 5mph with a 72" 37 hpZTR I have. That 72" finish mower you have & only one tree, should be a pieceof cake.I haveover 100 trees to go around & did that without ZTR for a very long time, there is so much you can do with tractor that ZTR can, a seriouse 1 trick pony they are. You can get a bazzion differant attachmentsif you ever decide togo to war with your lawns & anythingelse you can thing of. I would not sell what you have for simply wanting a ZTR,Now having both is a differant story..*s* I almost sold my ZTR because of it bieng so rough here, so now I spent all summer, filling & grading & next year will be able to fly much faster, but if not for the 100+ trees to go around, I never would have got ZTR. I would have bought a killer finish mower the exact size you have
Joe
/ What are these implements worth? #5
I tried out a ZTR and I am glad I did. It did not do well on the hills of my lawn. Strait up and back down, OK. Drive down forward was like riding a sled. and traversing the slope it was constantly fighting its way down hill. I took it back and bought a BX1500 and feel like it was the best move for my property.
/ What are these implements worth? #6
I don't see how you can maintain a lot that size with just a ztr. If you get caught in the spring and it is too wet to mow for a couple of weeks you will be hosed without the power of your tractor.
Keep the tractor and buy a ztr. You will have the best of both worlds.
Okay, okay, you guys wore me down! :D
I'm gonna attach the finishing mower and try it out in a high range gear some time this week. Any suggestions on what speed works the best? I usually brush hog in H2.
BTW, I'm soliciting some input about the PTO speed selector on a thread down in the Mahindra owners' section-I can't seem to get the PTO to work in anything but the HI (1000 rpm) range, and I'm thinking that's a bit fast. What speed do y'all use when using brush hogs/finishing mowers?
/ What are these implements worth? #8
As far as I know all 3pt implements use only 540 rpm pto.
Russ
Went home at lunch and tinkered with the PTO selector, it was (gasp) user error/idiocy. Turned it on at low (540) rpm, and the bush hog worked fine. Plan to run the finishing mower tonight in H3 or so, and will let y'all know how this goes.
/ What are these implements worth? #10
*I took it back and bought a BX1500 and feel like it was the best move for my property.
Congrats on the BX1500 .
It will do so much more than a Z T R >
I fully agree with the other poster that you need to demo a ztr on your property for a complete mow before you buy.
I did not do this & am completely redoing my 5.8 acres so I can actually go faster than 5mph with the 72" 37 hp ZTR I have.
That 72" finish mower you have & only one tree should be a piece of cake.
I have over 100 trees to go around & did that without a ZTR for a very long time.
There is so much you can do with tractor that ZTR can't do; a seriouse 1 trick pony they are.
You can get a bazzion differant attachments if you ever decide to go to war with your lawn & anything else you can think of.
I would not sell what you have for simply wanting a ZTR.
I almost sold my ZTR because of it being so rough here.
Instead I spent all summer, filling & grading & next year i will be able to fly much faster, but if not for the 100+ trees to go around, I never would have goten a ZTR. I would have bought a killer finish mower the exact size you have.
Joe
Very good advice and points.
Hooked up the finishing mower last night, which it turns out works. I can definitely go it at a faster pace than the riding mower, but I'm unsure about the quality just yet. Grass is freshly cut.
I paid a guy to come in and cut the "front," which is about 1/2 the place, due to schedule keeping me from doing it this week. He had an exMark, I think, and it took him about an hour, maybe an hour and fifteen, to cut that 4 ish acres. Anyhow, I went down and tried to cut some of the pasture with the finishing mower to see how it would do, but all the clumps o' grass from the last bush hogging seemed to give it fits, so I won't be able to tell until the grass grows up a bit more on the front half. I'll keep you posted....
Meyer 8' Snow Plow w/ Bracket (A55272)
Meyer 8' Snow Plow...
14ft Flatbed Truck Body (A59230)
14ft Flatbed Truck...
2018 FREIGHTLINER M2 FORESTRY UTILITY BUCKET TRUCK (A59823)
2018 FREIGHTLINER...
207275 (A52708)
207275 (A52708)
2007 Ford F750 Bucket Truck (A60352)
2007 Ford F750...
2021 Takeuchi TL6R High Flow Compact Track Loader Skid Steer (A59228)
2021 Takeuchi TL6R...
