What are the odds?
/ What are the odds? #1
DwightD123
St Louis Mo
LS R4041EZ
I think this would be an interesting thread but could easily wander outside of parts/repairs.
My "What are the Odds?" question comes to you today from our proud sponsor "Grease Fittings".
On greasing one of my fittings I noticed the grease coming back out of the fitting when I took the grease gun off. Ok no biggie..figured it got dirty or damaged..sure enough upon close inspection it was flattened at an odd angle..probably from brush. So I go to put on another one and it does the same thing...now I'm thinking what the crap...no way a brand new one is doing the same thing so I look all over..cant see anything wrong at all...try it again...still letting grease escape. So I grab another new one and it works...what is going on?
Is it really that common or is there a trick I am missing for these things?
Anyone have the same issues?
/ What are the odds? #2
I would say you got the one new one that had a bad spring or missing spring and it did not seat the ball back, or you got the one built on a friday
/ What are the odds? #3
There are probably more qualified authorities out there than I am, but my only suggestion is that those fittings were bad or defective. Only a hypothetical guess. Possible? Perhaps. You didn't mentioned where the fitting was. You mentioned the possibility of brush causing it. Happy Tractoring.:tractor::tractor:
/ What are the odds? #5
I agree.. first fitting was damage.. 2nd fitting was junk.. :)
soundguy
/ What are the odds? #6
Ive had bearings with grease fittings that did that before and I's had to clean out the bearing completely before I was able to get the grease fittings working again. The back pressure from the dirty grease caused anything but the tightest fittings to leak, but that tractor was in pretty rough conditions to make it that dirty.
Johnson 3pt 12' High Speed Disc Harrow (A64119)
Johnson 3pt 12'...
2015 Kenworth T880 QMC 8060R 40 Ton Tri Axle Straight Boom Crane Truck (A64194)
2015 Kenworth T880...
2019 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A59910)
2019 FREIGHTLINER...
2008 MACK CHU613 DUMP TRUCK (A63569)
2008 MACK CHU613...
2022 Greenworks CU400W Commercial Work Utility Vehicle DEMO UNIT (A63689)
2022 Greenworks...
2023 John Deere 8R 310 Tractor (A63111)
2023 John Deere 8R...
