What angle for weld-on Euro hooks?
   / What angle for weld-on Euro hooks?
Nothing at all. Just the ball. Mine uses 45 mm balls, being Cat 1, the hole is 7/8" if I recall correctly. This is truly a great system. More and more tractor manufacturers have been offering these as standard here in Europe.
My tractor came with a set of balls. I've since machined 2 more sets so I wouldn't have to move the balls around. They can just stay in the implements. I'm still one set short though but that's for an implement I rarely use.
Using my homemade ball turning attachment here.
You sir are an artist. That ball cutter is brilliant. Thankfully for me, the balls here are relatively inexpensive. Another plus for this system.
I hope it catches on here as well. Currently you generally only see these on larger tractors, or on some vintage tractors that used it for a time.
   / What angle for weld-on Euro hooks? #12
The balls are indeed very cheap. I could get them for $4 or $5 each but I've always wanted a ball turning attachment so this was a great excuse for that.
   / What angle for weld-on Euro hooks? #13
That's the benefit of connecting to balls rather than pins. This system can accommodate a wider range of angles. From everything I've seen, it renders the telescoping function moot.
It has little to do with the telescoping function. When you back up to an implement, if you aren’t 100% square, one arm will engage while the other is too far away to engage. This is where the telescoping arm allows you to pull the lift arm further back so it will engage the pins. Otherwise you have to keep jockeying the tractor to get perfect alignment or use a bar to move the implement into place. This is the same situation for both the standard and Eurohook system. There’s a photo that was posted that shows Eurohooks with a telescoping lift arm. You can have both.
   / What angle for weld-on Euro hooks? #14
You can have both, I build them that way all the time. Having the hook ends, the extendable feature is not normally needed though.
Say you back up to the implement, you are 1-2 inches from being square. Simply back up the needed distance pushing the closest side back using the riser on the hook until the further side is back far enough to line up. Raise the 3pt and the draft arms are connected. This is very easy if you have a hydraulic side link, even on uneven ground. But even without there simply is good reason to have both the extendable ends with the hook ends IMO.
I suppose that if you were connecting on a cement floor and did not want to scratch the floor needlessly, then there would be a purpose for the extendable ends. But if that is-was the case, it would be best to set the implement down on some plywood.
Each to their own, it all works easier than the std draft arm pins-ball swivels. :)
   / What angle for weld-on Euro hooks? #15
I guess it depends on the weight of the implement how much pushing you can do. I run cat 2 1000#+ implements.
   / What angle for weld-on Euro hooks? #16
So do I, I even have a couple of cat 2-3 implements up to 3500lbs. If your MX tractor can't push back 1000lbs, well good luck. I don't see an issue.
Just keep using your extendable ends as they are, easier than adding any hook-type connection at all and you're happy, so in your case, it doesn't really matter. (y):)
   / What angle for weld-on Euro hooks? #17
I can always make it work without telescoping arms or claws. But when you could have both options, why not?
I thought I answered that already, but I can put it in point form for clarity:
1. Telescoping arms are pointless on Euro hooks and using them would defeat the purpose of having a quick hitch system.
2. Expense. I'm keeping my existing ends, not modifying them. The flat bar I'm using instead would have to be milled or table cut to get the slot right, so that means paying a shop. I don't have the flame skills to pull that off in my own shop.
3. Strength. Cutting out the middle third of the flat bar for a feature I won't need or use is an unnecessary strength penalty. A mild steel profile is not going to be as strong as the equivalent forged steel piece. Leaving the flat bar a solid piece should negate the difference.
   / What angle for weld-on Euro hooks? #19
Whatever floats your boat.
   / What angle for weld-on Euro hooks? #20
I think he was suggesting to just cut off the ball end (in red) and keep both functions just in case
Gleaner N630 Corn Head (Allis Chalmer Branded) (A56436)
Gleaner N630 Corn...
2008 CAT D6T DOZER (A58214)
2008 CAT D6T DOZER...
(INOP) HONDA RIDING MOWER (A58374)
(INOP) HONDA...
1993 Ford F-250 (A56858)
1993 Ford F-250...
towable flood lights (A56857)
towable flood...
2012 Ford Transit Connect Cargo Van (A56858)
2012 Ford Transit...
