What about antifreeze?
   / What about antifreeze? #1
HOMERUN7
The operators' manual does not say anything about using antifreeze in the DK35, only talks about pure water. Can you use antifreeze in the winter and what kind do you use?
   / What about antifreeze? #2
Mine came from the dealer with coolent premixed in the system. It appears to be normal automotive type. I would assume a normal 50/50 mix for those of us in the northern states. Either way it does more than protect against freezing so I'd put it in even if I lived elsewhere. I personally wouldn't use straight h2o. My 2 cents.
Thanks for your response. Would it be the regular green type or the GM DEX-COOL orange type?
   / What about antifreeze? #4
Mine has orange type, must be 'cuz it's an orange tractor, right? :)
   / What about antifreeze? #5
I have a truck with the dexcool that I am careful to flush on a rigorous schedule. There is a huge contingent of folks who seem to think that this stuff is evil. They call it deathcool.
My Kioti has green antifreeze. I would recommend the common plain jane green antifreeze unless your engine has already been filled with dexcool and then you should stay with it.
Green sounds good to me! Thanks.
   / What about antifreeze? #8
I use Fleet antifreeze in anything diesel. Tractor Supply sells for approximately $10.00 per gallon. Information on Fleet Antifreeze at the link below.
Fleet Charge Antifreeze
   / What about antifreeze? #9
depratt_equip said:
Just use green, they come filled from the factory.
The color of antifreeze is no indication of the type of antifreeze that is installed. Here is a technical bulletin from the Filter Manufacturers Council that explains the different types of antifreeze and other details about the product. Possibly it is more information than the average person would want, but it will take less than 5 minutes to read it and it will give you a new perspective on antifreeze types.
Dusty
   / What about antifreeze? #10
Hi,
50/50 mix of permanent antifreeze is what we use in our pre delivery set-up.
It protects against freezing, overheating and also has a lubricant for the waterpump. Don't waste money on anything too fancy here.
KiotiDave
   / What about antifreeze? #11
Dusty
My poor Gruman body Freightliner with a ISB 5.9 Cummins feels left out, it's color isn't listed in that article. It has purple antifreeze. :)
I was unfortunate enough to be working at a International truck dealer when over the road tractors started switching from good old green antifreeze to the newer extended life antifreeze. What a disaster that was. First orange, then pink, then yellow, then blue... Drivers adding the wrong coolant when they needed a top off, others adding DCA to coolant that did not need it, others that did not add the needed extender additive at the scheduled intervals to extended life coolants. Then you had companies like CAT that realized the early silicate free coolants were causing water pump failures and had us add a silicate additive to the collant to update it. Just a big debacle. Numerous water pump failures, coolant gelling from mixtures of incompatible collants and cylinder liner cavitation leaks. I wish they would just bring back the good old day's of green antifreeze, test at every service interval with a DCA test strip and add DCA as needed.
   / What about antifreeze? #12
Dusty
Dusty, the link is very informative and worth the time to read it. Thanks for the enlightenment. ;)
   / What about antifreeze? #13
Upon further investigation, actually I didn't look before and relied on my sometimes faulty memory, my Kioti is filled with normal green coolant. Must have been the sun shining off that orange hood that deceived me :).
Dusty, thanks for the link, good info.
   / What about antifreeze? #14
Who said that Kioti and Kubota guys can't get along???? :D :D
(INOP) JOHN DEERE 544 AA WHEEL LOADER (A60430)
(INOP) JOHN DEERE...
JEEP FOR DOUBLE TRAILER (A58214)
JEEP FOR DOUBLE...
2014 Nissan Altima Sedan (A59231)
2014 Nissan Altima...
iDrive TDS-2010H...
2011 VOLVO A40F OFF ROAD DUMP TRUCK (A60429)
2011 VOLVO A40F...
2013 Godwin Dri-Prime CD103M Towable Trash Pump (A59228)
2013 Godwin...
