Wet area recommendations
/ Wet area recommendations #11
What is on the back or other side of the barn? might be easier to run drain there instead of under driveway. Pipe is cheap, driveway no so much.
Plant cattails:)
/ Wet area recommendations #12
At $65/hr, I'd be looking around the property to see if there's 10 other jobs he could do as long as he's already there.
/ Wet area recommendations #13
You need a rotary level and figure out where you can let that water out, Unless it obvious with your eye. Looking at your picture, I would dig a trench around the build and go through the driveway, and let it out somewhere or into another drainage ditch. You could also tie your gutters into that also. I would take grade sticks a put them every 10 ft and figure out the available pitch and lay it out before he comes in with the excavator. have him dig it while you work the level and it probably wont be more than a two hour dig.
/ Wet area recommendations #14
Wish it were $65. per hour here! lol! --- anywhere from $95. to $175. depending on who you get.
/ Wet area recommendations #15
a gutter for the roof would be very cheap and centralize all the runoff into one spot.
Skid steer Asphalt attachment (A61567)
Skid steer Asphalt...
(INOP) 2019 FORD EXPLORER (A59823)
(INOP) 2019 FORD...
2025 Hydraulic Trencher Skid Steer Attachment (A61567)
2025 Hydraulic...
Kubota RTV X1140 (A60462)
Kubota RTV X1140...
SKIDDED WASTE WATER FIBERGLASS TANKS (A60736)
SKIDDED WASTE...
SKID STEER ATTACHMENT SIFT BUCKET (A58214)
SKID STEER...
