Well, Well, Well! There's air in my water....
   / Well, Well, Well! There's air in my water.... #1
jayste
Veteran Member
"Sold the 1/4 of a 1/4 but still tractorin' "
2004 Kubota M4800 SU
Late Saturday's water supply seemed a little "airish". Not having worked on any water line to introduce air into my water system, I got a little concerned. The air was in both the hot and cold side and at all faucets and toilets so I knew it was in the whole water line. After studying on it a while I decided to take a look out side. We're on a water well system and has been pretty flawless other than the usual "seasonal" problems. The well was originally drilled and pump installed 14 yrs. ago. I've had small issues such as pressure switch failure/clogged 1/4" nipples and such but good service for the most part. This situation was different than most due to the air in the line similar to cutting into or "opening" the line to work on it. I first walked the area in the yard between the well house and the house to look for wet spots in our very dry ground. Even though this would probably just create a reduced pressure situation in the line I wanted to start out basic and work up from there. No wet spots so I went to the well house to check things out. All things seemed in order there except for the very obvious cycling of the pump. Noticeable only by the "humming" of the pump (it's submeresable), the pressure switch kicking on and off and the pressure gage going up and down. All of this with an average of about 10 seconds of pump on in a 50 seconds off time cycle....not good. Now, I'm thinking the system in not holding pressure. Just for giggles I check my pressure tank for air pressure and check for water in the tank. All seemed good there with no water coming out with the air. Now my thoughts are on the pump, check valve and stand pipe. I couldn't remember how deep this well is. (we have two well: one for us and one for the farm house). Let's face it, I'm getting older and it's been 14 yrs since we installed it!:eek: Anyway, I decide to concort with a fellow who I consort with on these kind of matters and after chewing on the same cud and getting the same juices we narrow it down to a split in the the stand pipe or a bad check valve. Something is allowing it to draw air. At this time things started come back to me like:
1) we used 20' joints of sch 40 PVC pipe not sch 80
2) we used sch 80 PVC fittings
3) pump was bought new and was 14 yrs old
4) A fellow I used to work with and I installed the pump and all workings to finish it out.
Now it's Monday morning and I've called in to my job to take a day of "vacation"!:mad: Thankfully, I didn't enclose the well head too much. When I built the well house (8'x12' storage/well house) I put it just in front of the well head and built a small enclosure to attach separately behind the well house and over the well head. Since that time I've added a lean-to on the back of the well house so I've got that to deal with. First things first so I had to remove one sheet of corrugated iron off of the roof of the lean-to to allow the 20' sections of pipe to protrude into the air as I pull and install the pipe. Next was to open up and remove the enclosure around the well head. After exposing the well head came time to disconnect the wires (after shutting off the breaker and insuring the power is off). Mine is the style where you have a well seal that installs in the casing at the top and the PVC pipe runs through the middle of it into the casing and the wires and well rope on each side of that. Not having a union I had to cut the pipe at the top in order to start pulling the pipe. Before I started pulling the pipe I knew I would need a "pipe block" for the fittings to rest on while I disconnected each 20' section as they are threaded together. As I'm pulling I'm having to cut loose each piece of tape where we taped the wires and the rope to the pipe with electricians tape. Thankfully the stand wasn't too heavy due to it only being 100 ft deep and void of water in the pipe! Which, by the way, told me, as I was pulling the pipe out, that the problem was down low being that each section of pipe wasn't full of water. Finally, as I reached the last section of pipe that has the pump attached I could hear water draining from somewhere which told me again it was in that particular section of pipe. Upon removing the pump from the well and observing it I noticed what appeared to be some pitting in the brass check valve that is inserted in the top of the pump between the pump and the stand pipe. For those who might not know the check valve is a "one-way" valve that allows the water to flow up, in this case, but not down. It allows pressure to remain in the stand pipe and water system. After removing the check valve from the pump and stand pipe I found the culprit. The brass valve had actually "washed out" and created a hole leading from the inside about the last threads (deepest) to the outside of of the valve allowing water to drain back down once the pump would shut off.
Wow! I just realized how long this post is! Anyway, sorry for not having any pics of the job (maybe I can add some later of a few things) and maybe this can help someone who might have this type of problem in the future.
   / Well, Well, Well! There's air in my water.... #2
Jay, do you have a bladder tank or a galvanized tank? The reason I ask is that I have a galvanized tank. On the pump side of my check valve at the inlet and about 20' down the pipe, there is a hole that the well driller drilled into the PVC pipe. At the top of the inlet pipe before the check valve, there is a shrader valve. When the pump shuts off, water is allowed to drain out of the first 20' of pipe and the shrader valve lets air in so that when the pump starts, there is no head pressure in the line.
Now, the slug of air in the first 20' of pipe is pushed into the tank each time the pump starts. There is a float valve on the side of the tank which has the sole function of bleeding off the accumulated air inside the tank. As the water level drops in the tank, the float on the valve drops and opens the top of the tank so air is allowed to escape. When the pump starts to fill the tank, the float valve closes and the subsequent air pocket is maintained so that the pump builds up pressure and compresses the same sized pocket of air with each cycle. If the bleed valve on the tank stops up, then the tank fills with air and it starts causing water hammers in your pipes and spewing out with the water. When you first described your problem, that's what I immediately thought of.
I'm not exactly sure how a bladder tank works, but the also have some way of relieving trapped air. If the bladder fails, what happens is your pump comes on immediately as soon as you open a spigot because there is no air around the bladder to compress and maintain head pressure inside the tank.
Hello Jim. Yes, I have a bladder tank. You mentioning your set up is the first I've heard of this type of system. Of course, I only know the ones that I've worked on and that ain't much!:D
   / Well, Well, Well! There's air in my water.... #4
Jinman,
that is the same system I have. That is what I was thinking too.
Jayste,
Can you post a picture of the bad valve?
   / Well, Well, Well! There's air in my water.... #5
Would that be what is called a two way check valve?:)
   / Well, Well, Well! There's air in my water.... #6
That is also called a foot valve, and is a one way check. The column of water keeps the check closed until the pressure is relieved by the pump sucking water up through the pipe.
   / Well, Well, Well! There's air in my water.... #7
at least you had threaded 20 foot sections. you could take apart. and not having to cut each one and put in new fittings for all the sections.
at least it was at very bottom were valve was and leaking. trying to pull up pipe full of water is no fun at all!
in a way i would be thanking my lucky stars. you got away with an easy fix!
pain yes. but it could have be a lot worse!
Jinman,
Jayste,
Yes, I'll get one this evening.
:D
JJ, my pump is in the hole and pushing up.:)
Yes, you are correct. My son and I pulled one about 5 yrs ago at the farm house due to a bad pump. All sections were full of water....not fun even for the young!
Now a question for the number junkies.....I've got 1" ID pipe, it's 98' long, how much volume? Then convert to gallons X 8lbs/gal for water and tell me how much more fun I missed out on!:laughing::thumbsup:
   / Well, Well, Well! There's air in my water.... #9
Quote: Now a question for the number junkies.....I've got 1" ID pipe, it's 98' long, how much volume? Then convert to gallons X 8lbs/gal for water and tell me how much more fun I missed out on!
According to my math you missed out on 31.9872 pounds of fun.:D
   / Well, Well, Well! There's air in my water.... #10
No way!!!!!
Pull it up short of the roof cut it off repeat as needed to get all the pipe out .
reinstall it with polyethylene pipe on a roll.
My well is 450 ft deep with sch 120 pipe for the first 210 ft poly the rest.
The 120 is because well only has about 40 ft of water in it at the bottom . and pressure is higher than poly would handle down there.
tom
   / Well, Well, Well! There's air in my water.... #11
Although poly has been the norm here for the last several years, for holding a stand of pipe while a joint is being unscrewed I've found a pipe vise laid on the casing comes in mighty handy. A helper can unlatch and re-latch just as a coupling comes by.
   / Well, Well, Well! There's air in my water.... #12
If you were in Pennsylvania I would tell you to check the water with a lighted match at the spigot. #$% frackers!
Here's a few pics after the fact. A couple of the culprit (check valve) the light showing through the hole, one of the well head before I closed it back up and one of the block (notched 2x6) to hold the pipe stand while I disconnected/connedected the joints. I put a fitting in it to give visual aid.:) Sorry, pic quality is pretty poor. Sandbur and Tom I agree on the poly. I think later workings will call for replacing the PVC like when I have to replace the pump. Al, no problem with well frac'ers around here...YET! Thank goodness.
Oh! I almost forgot...Yep! Sandbur, I rounded it off to 32#'s. That's 32lbs I'm glad I didn't have to pull from 100' below!!
   / Well, Well, Well! There's air in my water.... #14
The notched 2x6 is a terrific idea.:thumbsup::thumbsup:
Yep! It's quick and dirty and works like a charm. I think I borrowed the idea from someone?! Anyway, beats using a set of slips on the slick pipe or having to hold it and work one handed!:D:thumbsup:
"well", I'm back at it! I'm picking up a new pressure tank today. Apparently, when I replaced my old pressure switch with another that I had on the shelf (used, in good shape but disfunctional) it caused a high pressure situation in my tank and ruptured the bladder!:mad: I only replaced the one that was in service because it showed a little sign of an old leak at the diaphram area. Today's purchase will consist of a new tank as well as a new presure switch. The saga continues.......:(:confused2:
   / Well, Well, Well! There's air in my water.... #17
Jay, I hope all is going well (no pun intended). I know I get terribly frustrated and upset when one problem fixed just leads to another. Hang in there.:thumbsup:
   / Well, Well, Well! There's air in my water.... #18
Jay, if you aren't as busy as a one-armed wallpaper hanger, we'd sure like to know that you are okay. Working around a well pump and electricity always has its dangers. You've also had some bad storms in your area lately. It's just not like you to not follow up on a thread without good reason, and I'm just concerned.:confused3:
Mr. Jim! Thanks for the concern! No, I'm here to tell about it. Just got busy this morning. Well repair went "well".:laughing: Purchased a new tank and switch and didn't even have to drive the 20 miles (one way) to get extra parts! Along the lines of being concerned about me I do have to make a mental note. When you go to cut into the 1" PVC line between the tank and the brass tee, bleed the system of water pressure!! I couldn't believe I did it but when it went I sure got it...WET! I don't know about a one-arm wallpaper job but I felt like giving a one-legged man butt kicking and that would be my own! Anyway, no water or electricity came together except where allowed. All seems to be in working order. Storms you say?.....We had a few around us but what we did get was a much needed 5 1/2" of rain!:thumbsup: All four ponds are full and the weeds....er, I mean grass is loving it!:laughing: Have a good one!
   / Well, Well, Well! There's air in my water.... #20
Well, as long as you and your family are okay, it's all good news.:thumbsup:
(2) 330 GALLON POLY TOTES W/CAGES (A60432)
(2) 330 GALLON...
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
1995 FORD LTL9000 FLAT TOP DAYCAB ROAD TRACTOR (A60430)
1995 FORD LTL9000...
TANK MANIFOLD (A55745)
2015 Ford Escape SUV (A59231)
2015 Ford Escape...
2021 Gehl RT215 Track Loader with 74in Smooth Bucket (A61306)
2021 Gehl RT215...
