Lloyd_E
Veteran Member
- Joined
- Nov 15, 2003
- Messages
- 1,475
- Location
- South Shore Nova Scotia Canada
- Tractor
- 2008 Kioti DK 45 sc
Once again I turn to the wisdom and knowledge of you folks.
19 year old well pump and switch. Replaced the tank last spring.
Shallow well pump - Red Jacket. Pump and tank is in basement.
For about the last 2-4 weeks it seemed to take forever to fill tank.
I checked pressure at tank = 26 lbs of air. Pressure is good in the house, sink, shower etc.
I tried adjusting old switch but it only got worse. This morning I replaced the old switch(only had one spring adjustable setting nut) with a new switch that has two adjustable spring setting nuts. It was supposed to be factory set at 30/50 psi. Took forever to get the thing adjusted. The best pressure I can get is 28lbs at pump - also put in new gauge this morning. The pump clicks on around 18lbs and will go to about 28lbs and shut off. Lots of pressure in lines but seems to take a long time to fill tank.
I tried adjusting both springs/nuts - got everything from not shutting off pump with pressure around 30lbs to loosing all pressure at pump, which I than had to manual turn on switch. Can't seem to get pressure above 26/28 lbs.
So, is it the tank again? Or is it time for a new pump? I drained tank of water and adjusted pressure as per instructions on the side of tank too.
Any thoughts would be appreciated.
TIA.
TIA.
