Well it worked
/ Well it worked #1
seedman4
I have a new mahindra 3525 tractor i bought last year.it did not come with rear remotes.called the dealer they said the option kit was around 600.00.So do it my self.i added a 5 gallon oill tank on the front end loader frame just in front of the right rear tire.then made a bracket for a log splitter valve and mounted it of the control bracket for the FEL.bought 2 HYD pumps that are rated 12 GPM.and 2 hoses.and the female HYD couplers.PUT IT ALL TOGETHER AND IT WORKS GREAT to run a single double acting cylinder...i bought 2 pumps because i had another tractor iwas going to do the same on but sold it...The other pump is for sale!!!!!
Any way spent $256.94 for the hole set up and saved money.by the way the added system is removable.and used only one pump..
/ Well it worked #2
How did you run the pump?
/ Well it worked #6
Sounds good. I never thought about a rear remote like that, but it makes perfect sense and is easily upgraded to as many remotes as your heart desires.
Homemade Trailer (A63116)
Homemade Trailer...
2017 Ford Expedition SUV (A61574)
2017 Ford...
2007 CATERPILLAR 725 OFF ROAD DUMP TRUCK (A62129)
2007 CATERPILLAR...
2025 48in Drum Mulcher Skid Steer Attachment (A61572)
2025 48in Drum...
2022 John Deere 5055E (A60462)
2022 John Deere...
2021 Bobcat T76 Compact Track Loader (A64047)
2021 Bobcat T76...
