Well . . . I Gotta Problem
/ Well . . . I Gotta Problem
Thanks again for all of the replies. It looks to me like regardless of the source of the sediment I still need to install a whole house filtration system (a good idea even if I didn't have that problem). I am also going to have a well service company come out and check my liner to ensure that it is intact. I know that they can be sleeved with PVC if they are not too far gone. Hoping for the best.
Kevin
/ Well . . . I Gotta Problem #22
</font><font color="blue" class="small">( I agree with the others,
*****the close new well probably dislodged the dirt... I'd pull the filter out, and let water run at that point for a bit to flush the system.
Soundguy )</font>
*****Any change on the land can affect a well.
When I first moved here in 1966 I had a well drilled down to 55 feet and hit a good vain of water then went on down to 80 feet which gave me a good pocket of water.
This well produced 5 gallon of water per minute which is an extremely good volume of water for a drilled well in my area.
In 1971 I had my whole 2.33 acres re graded with a dozer.
A few days after the grading I ran out of water and the production rate of the well dropped to 1.5 gallons of water a minute.
When I had the place graded I must have cut into 2 of the main veins of water that was feeding the well thus diverting this water away from flowing into the well.
I have 2 wet spring areas on the property that weren't there before grading.
2011 Bobcat E80 (A64126)
2011 Bobcat E80...
2023 Blue Diamond 103030 Extreme Duty Cutter (A65640)
2023 Blue Diamond...
John Deere 925 Cultamulcher (A66408)
John Deere 925...
New Holland LB75B Backhoe (A62613)
New Holland LB75B...
John Deere 1025R (A62177)
John Deere 1025R...
2011 CASCADIA 6X4 T/A DUMP TRUCK (A59914)
2011 CASCADIA 6X4...
