Welding question.....HELP!!!!!
/ Welding question.....HELP!!!!! #31
This thing can lay down some weld in a hurry and sometimes the welds don't turn out as well as I woudl like because I feel 'rushed' due to the speed of the welder
any lack of penetration?:D:D
/ Welding question.....HELP!!!!! #32
Charlz, I have a Miller similar to yours, I have found .30 runs the best, at least for me.
No luck with the electrode speed adjustment?
I have tinkered with that some, probably really need to take some notes as I weld and see what I like. I know some of the reccomended settings, like those for 5/16 material and I think at 1/8th are butter smooth. Most of the projects I weld there really isn't enough welding to spend a lot of time tinkering and my scrap cans don't have a large variety of material thickness to play with.
/ Welding question.....HELP!!!!! #33
Truthfully it varies... I like the "I am a guy with welding equipment, I am not a welder" quote I read on here somewhere. :D This welder puts out a lot of heat and prettiness is more a problem than penetration :eek:
/ Welding question.....HELP!!!!! #34
One thing that will help slightly is to clean the mill scale off the tube with an abrasive means of your choice before welding.
/ Welding question.....HELP!!!!! #35
Looks like the OP's hand wasn't steady. Use 2 hands. Preferably use a rest of some kind under your arm. Think about target shooting. You are far more stable with 2 hands and a rest than with the gun (MIG gun or firearm) held in one hand. If you shake sideways, you're welding on cold metal. Up and down; screwing up the wire feed rate. Maintain the correct stick-out.
Most smaller machines have "relative numbers" for voltage and wire speed. Mostly because it's expensive to control those variables to specific values. The settings from the chart on the welder are "starting points" Best settings for your welder may be a good bit different. Try having someone gradually change the wire speed as you weld a bead. Then compare the best speed to the chart. Pull the trigger and watch the wire feed. It should be smooth and consistent. If the wire speed varies the weld varies.
As for duty cycle, my machines weld fine 'till the overtemp sensor shuts 'em down. The smallest machine we have is 180 amps so it may not be a good comparison but Miller makes top of the line stuff so I wouldn't expect the weld quality to deteriorate as you approach max duty cycle.
2016 DRAGON SAND CONVEYOR (A58216)
2016 DRAGON SAND...
CATERPILLAR 299D2 SKID STEER (A60429)
CATERPILLAR 299D2...
2023 Global Trailers GT302 30 Ton 60YD T/A End Dump Trailer (A59230)
2023 Global...
2012 Ford F-350 4x4 Ext. Cab Pickup Truck (A59230)
2012 Ford F-350...
2018 Husqvarna 21in. Push Mower (A59231)
2018 Husqvarna...
2005 JOHN DEERE 160C LC EXCAVATOR (A59823)
2005 JOHN DEERE...
