Welding on nuts without damaging them
/ Welding on nuts without damaging them
Now the best solution. Dont stick them on, TIG them on.. much better control of the process and much better results..
See, that's what I said to my partner! I need a TIG torch for this job! She just rolled her eyes. Frankly, I plan to keep practicing stick for a bit before I spend any more money branching out into another process. I have a tendency to do the first 10% of learning on a subject, and in the mean-time buy the first 50% of equipment. Then I move on to the next subject. I've been trying to flip that ratio around.
That opens another option - tap the holes in the plate instead of welding nuts on the back. One less step and guaranteed to work.
That is tempting, and if I had a tap set, that's probably what I would have done. I confess I do like the visual effect that having the nuts there would have--so in his little toddler brain, he's seeing bolts going into nuts and associating them. Not that he's not going to figure that all out anyway, mind you.
/ Welding on nuts without damaging them #13
Try to weld the just the steel plate and just get the puddle to touch the nut. Since the nut is not much mass it will heat very easily. Also unless you need to bonded to the steel well just weld it on two sides. If you use a bold to hold the nut make sure to center it and only tighten finger tight (avoid putting stress on the nut). Watch out for splatter. Any on the threads will damage them and if not removed will ruin the threads. Avoid welding stainless nuts if possible. Stainless will gall so even the slightest distortion will ruin the threads. Finally go on ebay and buy some weld nuts, much easier to weld and they aren't expensive.
/ Welding on nuts without damaging them #14
You can make a thread chaser with a bolt, cut 3 or 4 angled cuts in the bolts with a hack saw. When I weld nuts on to a plate, I use a short bolt, coat threads with anti splatter tip paste, run the bolt threw the plate, hand tight. Tack on 3 sides and remove bolt. Nice project for a young mind, they are never too young to learn.
Dave
/ Welding on nuts without damaging them #15
I suggest you buy the kid more accident insurance because he will sooner of later drop it ,step on it ,fall on it ,or throw it thru a window , spend $5.00 and go to walmart and buy him something he won't hurt himself with , My kids at that age ( they are in their 30's now ) would have killed the dog swinging the block of steel on the chain !:2cents:
/ Welding on nuts without damaging them #16
I'd just tack the nuts on...and I'd use TIG welding...easier to concentrate the heat.
/ Welding on nuts without damaging them #17
As others said, TIG is the way to go for attaching nuts that small. And MIG is not bad either.
Are you just tacking them on? Or trying to weld them in full (IE: practicing??) Cause if it were me, I just tack a couple of spots on each nut since it isnt going to be load bearing.
Also, I think 110a is a bit too hot for a small 3/8 nut. With 3/32 rod, I'd probabally run around 65-70a on a DC machine. Maybe a tad more on an AC machine.
/ Welding on nuts without damaging them #18
If you think welding a steel nut on is tough, try welding an aluminum one.:D
Not necessarily a nut, but pipe insert.
Well, you sure do live up to your name! :laughing: If a five-dollar Wal-Mart toy would keep him out of my tool box, you better believe I'd do it. He doesn't want plastic tools. He wants the real thing, like his dad has. At this point, my fallback plan is to try to keep him away from tools that can actually injure him, and keep him using them places where he's not going to knock any holes in the wall or what-have-you. As for dropping it, stepping on it, falling on it... if that's the worst thing that happens to him in any given day, I'll call it a win. I turn my back for two seconds and he's climbing up a ten-foot ladder propped against the wall, or climbing the cattle racks on my trailer, or trying to stick a screw into an electric socket. I don't let him do those things, but I have to let him do something with himself or he'll just go crazy with boredom. So he gets to carry around the mallet if he wants to, and if he drops it on his foot, his foot might bruise, but it'll heal, and he'll be okay, and next time maybe he won't drop it. We had a hard time "teaching" him about the electric fence, but we used the same philosophy. We can shoo him away from it all day long, but let him touch it and get shocked a time or three, and he'll keep himself away from it just fine. And he does. Shoot! He reaches over to pick grass or sticks out from the wires and each time, his mom and I cringe, but he's figured it out just like the pigs have, which parts he can and can't touch without getting shocked. My point is that if something is actually dangerous or deadly (guns, knives, a hot wood stove, woodworking chisels, a circular saw), then I'm going to keep it away from him, but if it is only mildly injurious, I'm happy to let him figure it out, even if it means he gets hurt sometimes.
As for throwing it through a window... well, he hasn't quite got the coordination to throw things yet, but if he starts picking up the habit, then I'll reassess his access to heavy projectiles.
/ Welding on nuts without damaging them #20
I hope that posting is a joke because you can't teach kids the same way you do pigs ! :laughing: I can appreciate what your saying but I just noticed you live here in Knoxville and some people around here are a bit overzealous on child protection rules:hissyfit: I'm sure you know what I'm talking about ,but at 17 months they don't get to pick what they are allowed to play with:pullinghair: and even if it's just "mildly injurious " you could go to jail !:yuck:
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55851)
iDrive TDS-2010H...
Case-IH 180 Magnum (A57148)
Case-IH 180 Magnum...
2005 SHOP MADE MANIFOLD TRAILER (A60736)
2005 SHOP MADE...
John Deere 6300 (A60462)
John Deere 6300...
10,000 PSI AIR HYDRAULIC PUMP (A58214)
10,000 PSI AIR...
2014 Toro Z-Master 6000 Series 60in Zero Turn Commercial Mower (A59228)
2014 Toro Z-Master...
