welding on atv
/ welding on atv #1
mbown
Indianola Iowa
260 c ford new holland
I need to do some welding on my Artic Cat 375 hitch. My concern is what do I need to do before welding Or is it of any concern? to protect the alternator?
/ welding on atv #2
Disconnect the ATV battery and keep your welding ground close to the hitch you are welding.
/ welding on atv
Thanks for the quick reply,will proceed from here.
/ welding on atv #4
I have also either removed or thrown a wet blanket/towel over anything that can catch fire or melt from welding sparks. Like plastic seats or fuel tanks - especially fuel tanks.
/ welding on atv #5
Good plan.. Also I always do a double ground when ever electronics are concerned. Use the welder ground close to the joint and I run another to earth or another source. You wont have any probs.
/ welding on atv #6
Can't go wrong by disconnecting the cdi, battery, keeping ground clamp as close to the weld as possible and a FULL gas tank.
An extinguisher-ABC type nearby and a quick means of egress; keep your path to the exit clear.
Sent from my iPhone 5s 64Gb using TractorByNet
(2) 380/85R28 TIRES W/ 10 LUG RIMS (A64280)
(2) 380/85R28...
2004 Lincoln Navigator SUV (A61574)
2004 Lincoln...
2017 Ford Fusion Hybrid Sedan (A61574)
2017 Ford Fusion...
2021 CAT 289D3 (A60462)
2021 CAT 289D3...
Willmar Fabrication 915 (A64119)
Willmar...
Caterpillar 322B/325B/325BL Excavator Service, Parts, and Operation Manuals (A63117)
Caterpillar...
