welding on atv
/ welding on atv #1
mbown
Indianola Iowa
260 c ford new holland
I need to do some welding on my Artic Cat 375 hitch. My concern is what do I need to do before welding Or is it of any concern? to protect the alternator?
/ welding on atv #2
Disconnect the ATV battery and keep your welding ground close to the hitch you are welding.
/ welding on atv
Thanks for the quick reply,will proceed from here.
/ welding on atv #4
I have also either removed or thrown a wet blanket/towel over anything that can catch fire or melt from welding sparks. Like plastic seats or fuel tanks - especially fuel tanks.
/ welding on atv #5
Good plan.. Also I always do a double ground when ever electronics are concerned. Use the welder ground close to the joint and I run another to earth or another source. You wont have any probs.
/ welding on atv #6
Can't go wrong by disconnecting the cdi, battery, keeping ground clamp as close to the weld as possible and a FULL gas tank.
An extinguisher-ABC type nearby and a quick means of egress; keep your path to the exit clear.
Sent from my iPhone 5s 64Gb using TractorByNet
2017 Ford Escape AWD SUV (A61569)
2017 Ford Escape...
2025 Swict 78in. Bucket Skid Steer Attachment (A61572)
2025 Swict 78in...
2020 Broyhill Load and Pack Articulated Solid Waste Handling Vehicle (A59228)
2020 Broyhill Load...
PALLET OF SCRAP AND TIRE (A63291)
PALLET OF SCRAP...
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2020 CHEVROLET...
2006 GMC Savana 3500 Box Truck (A61573)
2006 GMC Savana...
