Welding a Fireplace Heatalator
   / Welding a Fireplace Heatalator #1
Industrial Toys
Super Star Member
Ontario Canada
Kubota R510 Wheel Loader + Cab and backhoe, JD 6200 Open Station, Cushman 6150, 4x4, ten foot 56 hp Kubota diesel hydraulic wing mower, Steiner 430 Diesel Max, Kawasaki Diesel Mule, JD 4x2 Electric Gator
I have a 45 year old Fire place Heatalator (sp?) that is cracked.
Any suggestions on the easiest way to repair this?
Does it need material placed over the crack or would a bead do? It's irregular and putting something over top won't be easy. I would say the material is 1/16" or a little better.
I have a Lincoln 255 X(something) mig and an old Sears AC (Buzz Box) Welder. Which should I use? The Buzz Box would be much easier to get at the project.
I'm surprised that smoke hasn't been getting into the air system, so I'm guessing a perfect repair won't be necessary.
Thanks for the advice.
   / Welding a Fireplace Heatalator #2
You can fix it with either machine. 1/16 easy strike rod from MG would be great for a stick repair. 023-030 wire. You will want to try to clean it up better and try to close that crack a little more. Then drill a hole at each end of the crack to keep it from cracking further. Personally I would use wire. Just easier for me to fill gaps and you can do spots and stitches. I had an old Fuego fireplace that had a similar issue only vertical. Easy fix.
Thanks.
I guess at the end of the day, my question would be more, what can stand up better to the constant intense heating and cooling cycles if I just lay a bead? I use 035 wire and not sure what rods I have. Just some general purpose ones.
   / Welding a Fireplace Heatalator #4
Another suggestion.
Use some flat plate larger than the crack, smear some stove cement over the crack and using self tapping metal screws attach said 'patch'.
I would suggest the parch stock be one gauge thicker than the heat a lator.
   / Welding a Fireplace Heatalator #5
"Fire place Heatalator"<<<<<<<<I have no idea what that is but that crack looks like 1/8 heat distorted steel. I had one of them old Sears AC welders 40 years ago, my first welding machine, I weld the crap out of it.
Anyhow since that welder is easier to bring to the repair, I'd fill the gap with 3/32 6011, then a lap patch 1/8 x 4'' wide-ish, then weld that with 3/32 7014, <<<<you might have to weave a little so not to get slag entrapment, it's not penetrating rod but it makes a very strong weld, you're probably familiar with them since you have that old Sears buzz box.
There's probably a dozen ways to fix this and all will work...........
   / Welding a Fireplace Heatalator #6
Not to be Mr negative here but chances are it'll break again. If the original un-repaired piece broke, I'm thinking a repair will break also. You'd be better off using stainless rod, it'll give you a bit more flexibility. Just my 2 cents worth.................Mike
Thanks. Usually with Mig I weld new steel and am told the stick works better on old stuff, albeit probably DC. I never really understood why DC is so much better. That steel is so deformed and buckled that putting a patch on won't be easy.
A heatalator is a double walled steel box that they built a masonry fireplace around. It acts as a heat exchanger with vents connected at ground level sucking in cold air and others higher up to expel warm air through convection alone or with the help of a fan. Basically it increases the efficiency of a fireplace.
   / Welding a Fireplace Heatalator #8
Do not fix it if it is not broke . You start welding on that it will crack all to **** .
I have never smelled a whiff of smoke coming out the registers. Maybe I should just leave it be. I have a tube of high temp silicone open. Maybe just brush the crack clean and schmear some in.
   / Welding a Fireplace Heatalator #10
035 will be difficult unless you know your welder well and are a good hand with the gun. Or unless you spot the whole crack. Heat and cool should be ok unless you use a different make up of filler like Silicon bronze or stainless. I've also slid a backing plate in through the crack with a thin piece of tig rod tacked to it. Pull it up tight to the crack and tack the plate. I doubt you will need to that here. just do a bunch if spots and connect the dots. Many ways to fix this.
MCELROY PIPE FUSION MACHINE (A52472)
MCELROY PIPE...
2006 CHEVROLET SILVERADO 4X4 PICKUP TRUCK (A51222)
2006 CHEVROLET...
2015 JOHN DEERE 624K WHEEL LOADER (A51406)
2015 JOHN DEERE...
2010 CHEVROLET SILVERADO 3500 (A52472)
2010 CHEVROLET...
2018 INTERNATIONAL LT625 (A52472)
2018 INTERNATIONAL...
2007 Ford Crown Victoria Sedan (A51694)
2007 Ford Crown...
