Welder / Wiring for Small Garage
   / Welder / Wiring for Small Garage #1
dieselscout80
South Carolina
New Holland TC45DA
All, question on wiring and breaker for my personal use small garage.
I have a 50 amp circuit from my house to the garage on 6/3 wire (black, red, white and ground).
I planned to wire a 30 amp circuit for welding with 8/3 wire, but is that enough for say a Hobart Handler 210MVP or a Mult-Handler 200 Multiprocess? I wouldn’t ever need to weld anything thicker than 3/8”.
Handler® 210 MVP™ MIG Welder | HobartWelders
Multi-Handler 200 Multiprocess Welder | HobartWelders
Will a 30 amp circuit with 8/3 work?
   / Welder / Wiring for Small Garage #2
Here's what I use until I get my new shop finished. This is not permanently attached, it plugs into a 50A 4 wire outlet
   / Welder / Wiring for Small Garage #3
What are the input requirements stated in the manual? I used a 30 amp circuit for my Hobart 180 and it worked fine. For wire size, you need to look at both the amperage requirement plus the distance.
   / Welder / Wiring for Small Garage #4
I use a 30 amp for our Hobart 210 mig welder.
You know that they work on 110 or 220, the 220 is sooo much better, also with the aluminum wire gun.
   / Welder / Wiring for Small Garage #5
Doesn't that page for the 210 say it'll pull 24amps at 230V?
And the 200 says 19 amps at 240V?
The run from the house is less than 28’.
The garage is 20’ wide by 30’ long. I planned to put two 30 amp circuits one on each 30’ wall.
   / Welder / Wiring for Small Garage #7
How about hanging one from the ceiling right in the middle?:)
Climbing up to 135” tall rafters is not my favorite thing 🤪
2002 Wacker RD11A Tandem Smooth Drum Roller (A51691)
2002 Wacker RD11A...
UNUSED PALADIN SKID STEER HYDRAULIC BREAKING HAMMER (A51243)
UNUSED PALADIN...
2023 Globe Booster Flipaxle (A51572)
2023 Globe Booster...
2010 PETERBILT 340 (A52472)
2010 PETERBILT 340...
2012 CHEVROLET SILVERADO 2500HD (A52472)
2012 CHEVROLET...
Generac 5000Watt Heavy Duty Diesel Generator (A51691)
Generac 5000Watt...
