Welder Recommendations
/ Welder Recommendations #21
And of course I'll have to throw in my welder. The Harbor Freight 90amp basic no gas Mig. It's just a cheap welder that I use maybe once or twice a year and if all you are going to do is to fix broken welds or put a hook or two on a bucket and just not use it every day it'll do the job. For better looking welds and anything that you care about get a better one. I'd love to have a DC one too as mentioned the welds are better from them. But cost is a factor and my $85 bucks is working as intended.
/ Welder Recommendations #22
thank you Eddie and Arly.
one of my nbors in the country has a NG relay station welding fabrication business.. I will learn from him. I just today thought of getting my own welder, but wanted to seek your thoughts first. I'll ask my nbor too. Arly, cannot read that make and model? Can you pls post your welder info
30+ years ago I bought a used Ben Parsons 160amp MIG, for like $1k. It's more than paid for itself, several times over. I just replaced the torch (cable from the welder to your hand) 'cuz I melted it through, dragging it over a fresh/hot weld seam. The place I bought the welder from (in like 1987) is not only still in business, but had the "Binzel" torch in stock.
HTP: MIG/TIG/Stick Welders & Plasma Cutters | USA Weld
Buy a good unit (220v if you have that avail), from a local "old time" welding supply house. They were "local" at the time...
/ Welder Recommendations #23
Most of my welding is fixing old equipment, and doing favors for neighbors. I don’t do enough work to justify an expensive machine, so I started with a Hobart 140, but after awhile I decided to get a 220 v.
Got a good deal on the Yes 120/240v unit, and keep it at the higher voltage.
In the past 3 weeks, I welded a buddies front bumper back on his old Jeep, and repaired the hitch on a 100 gallon orchard sprayer.
It’s kind of a joke, but I always tell them, “no charge, and no guarantees “
The Hobart is used only for thin metal, and I probably have ruined more things than I have fixed
/ Welder Recommendations #24
Been a long time since I bought a welder, but I'd say buy an inverter mig welder. Be sure to buy good quality mig wire unless you want to clean off a lot of welding spatter that could have been avoided by buying good wire. Also buy a good helmet to protect your eyes and some decent welding gloves.
/ Welder Recommendations #25
Been a couple of years since I bought a welder.
My Lincoln AC stick welder was purchased in the late 70's,
then my Hobart Handler was bought in the mid 80's.
There is a small Miller stick welder sitting on a shelve in the back corner that I have never plugged in,
got it for free when I bought my old milling machine 15-20 years ago.
Then my wife just bought me a little ARCCAPTAIN TIG200PACDC which hasn't even been plugged in yet.
Been acquiring the miscellaneous bits and pieces to use it.
This may be interesting, I used to be quite proficient with torch welding and I had a welder back in the 80's that showed me how to TIG and coached me a bit when the job was slow.
/ Welder Recommendations #26
2 suggestions only... One, go to Harbor Freight and buy the welder you want. One, they have an iron clad guarantee two they are everywhere so no need to buy online or from Amascon becauae if the mail order welder fails, you are SOL and HF welders are very competitive, price wise.
Any welder you buy today (new), will be an IGBT machine. Transformer welders are no longer produced. I prefer a transformer welder but you can only buy them used today.
I would not buy a 110 volt welder and moden welders today are usually dual voltage anyway so at some point you get 220 in the shop, garage, you are in business.
220 welders are capable of a lot more amperage that a 110V welder, and IGBT machines atr very user friendly, the higher end IGBT machines even come with pre sets to make welding even easier.
For me, brand is inconsequential. All do the same thing basically so I buy mine from Harbor Freight. I realize they are built offshore but the days of domestically built welders are long gone. Even Lincoln Electric which is assembled here (Euclid, Ohio) are made with imported parts.
Myself, I own 2 HF welders, a TIG machine and a MIG machine that euns gas or gasless. I also own a Linclon gas driven ad/dc stick machine and 2 Hobart Handlers, 190 amp transformer machines plus 2 HF plasma cutters and a Hyper Therm plasma cutter. They get used almost every day as I own and operate a welding and machine shop.
Again, before jumping into ANY welder, go on HF's website and take a hard look at their machines. You won't be disapointed.
/ Welder Recommendations #27
Hello to all,
In my 60's and have had a ranch for 30 yrs. Any and all metal fixes I have taken to a nbor, but now it's time to get my own welder.
My main applications would be fixing existing broken things [like BBQ pits, metal fence, farm machinery, etc]. I am sure if I enhance my welding skills, I will engage in many other metal-based projects if I had one.
Looking for make and models of welders that would fit my needs. I know you get what you pay for, and not looking for really cheap products, but do not want to bust the bank either. If you have any questions, pls let me know?
Thank you in-advance for your help & suggestions!
If you have all new metal and looking for much work being done then buy a wire welder if you want. But sounds like you dont want to break the bank. Watch craigslist and pick up a good ac-dc machine. An ideal-arc 250 Lincoln would fit you nicely. Thats what I have. Lincoln is the smoothest. Trust me.
/ Welder Recommendations #28
I bought a cheap wire welder with an option for using rods. Then watched a lot of YouTube videos. I am no pro but I got the general concept before I went through the first spool of flux wire.
This is the one I found on Amazon.
135A Flux Core MIG Welder, 110V 3-IN-1 MIG/ARC/Lift TIG Welding Machine with 1 lb .030'' Wire, MIG Torch and 5 PCS Rods, Gasless Welder with IGBT, DC Inverter, Synergy For Repair Work​
Now I am willing to look at a better quality welder. 75$ was worth gambling to see if I could do it. I spent a minuim of 75$ everytime I had to take my projects to a welder. Now I only take him serious work that could threaten my life if my weld didn't hold. My welds are not nearly as pretty as his but I haven't had one fail yet. Welding with wire is really easy, much easier than stick welding...
Good luck
/ Welder Recommendations #29
Look up PrimeWeld you can get the 180 mig which is 110/220 volt, flux core/gas, stick and also comes with a spool gun for aluminum welding all for $500 with a 3 year warranty shipped to your door good luck
/ Welder Recommendations #30
I am a retired farmer,rancher,welder and I use flux core or DC stick.The best welding machines are the ones that do stick mig and flux core .I quit using the big name brands the new modern machines are just as good and sometimes 1/3 the price don't be afraid of them .I've been a welder for over 50 years.I usually use my vulcon215 with flux core and run it of my predator 8500 generator.
Hey Guys,
My brother has a Lincoln 140 Pro Mig Welder he's had for 1.5 yrs and wants $550 drive out. Comes w everything that was in the original box. It has the flux-core option so I'm not tied to only using gases. Can weld up up 1/4" materials, so for now, that should do me fine. He wants to get a larger welder, I believe a Miller 2XX. What do you guys think?
Note, I only have 220 for my electric dryer at ranch. The two places I plan on doing my welding are both 120V. But, I can easily upgrade one of the outlets to 220V if I ever need to do so.
Anyone have a PrimeWeld welder, esp the PrimeWeld 180? How do you like it and how long have you had it?
/ Welder Recommendations #34
Hello to all,
Although I have a BSME my welding knowledge was similar to grilling knowledge: I saw someone else do it. One of the very best moves I've made was to enroll in a 6 week, night course in welding. I had always been afraid of acetylene after experiencing an explosion as a kid. A short easy course will answer your questions regarding what equipment will meet your needs. AND you will gain knowledge. That's always a good thing. I now have a Hobart Beta-Mig, a Miller tig welder, and a variety gas cutting/welding equipment because I learned the basics of how to use them. You Tube has a guy doing testing at a site called "Project Farm". He does good testing and comparisons. Worth a look. I am certain he did a welder comparison. Every bit of my welding equipment was bought used on eBay or Craigslist. And, pay very close attention to "duty cycle", too.
/ Welder Recommendations #35
I have one, had for meny years. Many spools of wire have run through it. Both flux and solid. And aluminum never an issue. It also has stick leads come with it. I have a welder generator i use very little anymore I also have a miller mig I think it's over priced but good the PrimeWeld is my go to welder. I get nothing from PrimeWeld just my satisfaction of knowing it's a fair price and good quality for the price no other machine comes with a spool gun and a flow meter that I know of but could be wrong. 110 and 220 volt which is a plus. Check out their web site call order and you'll have it within 3 days good shopping and God bless
/ Welder Recommendations #36
'Shipped to your door'.... 3 year warranty... problem is, being an IGBT machine if it fails you get to ship it back (at your expense) and the primary reason when I run multiple HF welding machines and plasma cutters. If the fail, you take it back to your local HF store and they give you a new one. Much simpler and no hassle, plus HF's plasma consumables are very reasonable compared to say Hyper Therm (and I have one of them as well).
Not in order of revelance, I own Lincoln, Hobart, Everlast and HF machines and I own and operate a machine and fab shop so I always buy my equipment with longevity as well as guarantee in mind. I have employees using it, not just me.
Not a weekend welder at all.
/ Welder Recommendations #37
Good advice here. Learn to "stick weld" first, a Lincoln "tombstone" 225 AC/DC is what I'd recommend or a similar welder. MIG is great, but they don't like dirty metal, but If I had to pick a single good all round welder it'd be a "Stick" welder for general farm use. I've know several guys that ran before they walked and bought a MIG first and when presented with a stick welder because the MIG wouldn't weld it were dead in the water. I'd get a stick welder and try learning the "hard way," trial and error, then take a class at the local community college or trade school if you don't catch on right to start with. Do some reading on metal thickness and rod size. "My" rule of thumb, what ever diameter rod you're using, is the amperage to start with. A 1/8 inch rod is 0.125 diameter, set the amps at 125A, if you're burning through, weld/move faster or lower your amperage. Match you rod size to the metal thickness. Google around on YouTube, it'll help.
/ Welder Recommendations #38
LOL, you learn to do wit
I have no idea how folks get by with a 110volt welder!
You learn to do what you have! I have a VERY old Miller 120V 135 MIG, I use the piss out of it for a lot of things, usually 12 gauge metal and lower. But in a "pinch" I've been know to heat some "real steel" with a torch to red hot, turn the amps and wire feed up and get the job done. I have a Miller 252 with a spool gun and some TIG welders and a "tombstone" too. I use the 135 for most small jobs.
/ Welder Recommendations #39
So, scanned responses down to maybe 5 or 10; so someone probably brought it up.
This isn't 1980, you don't need to choose mig vs stick vs tig. I have a 4 in 1; DC stick, Flux core "mig", MIG, and TIG (no ac no hi frequency). It weights maybe 20#, is roughly 12" wide, 18" tall, and 24" long; and is 120/220V, and capable of running on a 110v/20amp recept or a 220v/30amp; all with included pig tails; for something like $270.
Yes, mine is a Vevor; but there are a dozen companies offering 3 in 1; 4 in 1; 6 in 1.
/ Welder Recommendations #40
I dont doubt Miller, Hobart, Lincoln, but your partly paying for name; partly for parts support, and likely a longer service life. For most people, a welder that will do more than 50# of rods or 100# of wire in its life is fine. Production shops, that's different; one of those might be asked to do 1000s of pounds of rods.
Couple hints; spend the money saved on the "box" on things like clamps, a "bar stool" height work bench, extra wire/rods, and a cheap, but not the Cheapest, auto dark helmet. I like MIG gloves for arc, as you have good movement; cotton/denim long sleeve pants, close toe leather boots/shoes, and atleast "should" have long sleeve cotton shirt. We have all probably welded in boxers and flip flops (or atleast I have), but slag/splatter in a flip flop/croc makes holding the bead hard.
Grinders; I have and like a Rigid 18V cordless, but there is no replacement for a proper plug in one too; I like Makita.
Rods/wire, and practice. Here's my thought; I'll take a guy with a HF/Amazon multi process machine, that's ran 25# of wire/rod over a guy that spent everything in a Miller, and didn't have money to practice.
Once you get it; play with it; weld some bolts to plates; do some butt joints, some lap joints, and don't worry about some of it being ugly
HYD OIL, OIL & USED OIL TANKS (A60429)
HYD OIL, OIL &...
2020 GMC AT4 CREW CAB TRUCK (A65054)
2020 GMC AT4 CREW...
New/Unused Wolverine Quick Attach Trencher (A65583)
New/Unused...
2013 DRAGON  130BBL VACUUM TRAILER (A65643)
2013 DRAGON...
ALLMAND MAXI LITE 8KW LIGHT TOWER (A65643)
ALLMAND MAXI LITE...
Landhonor BH-12-72D Backhoe Skid Steer Mount (A62679)
Landhonor...
