Welder Question
/ Welder Question #31
Interesting I have hit the thermal shutdown on my welder many times over the years (i got in 2001).
I do bevel when welding thick steel, but I see a lack of penetration when welding thick stuff.
On thick material, I run a downhill pass with my Titanium 125 Fluxcore welder. I bevel to feather edge then gap about 3/32". I find that the machine on G6 runs a fine root pass. Then I clean up the root pass with a grinder and run the rest uphill. Flat or horizontal I do the same but slant the tip of the gun a bit more into the weld puddle. The more vertical you get with the tip angle, the more penetration you get (sometimes much more than you want). Then I just drag the tip toward me, keeping the wire feet embedded in the puddle with a little side to side motion to tie into each bevel.
Coats 1055 Direct Drive Wheel Balancer Machine (A59230)
Coats 1055 Direct...
2020 DRAGON ESP 150BBL ALUMINUM (A60736)
2020 DRAGON ESP...
2012 UTILITY REEFER TRAILER (A58018)
2012 UTILITY...
2015 Ford F-350 Versalift Bucket Truck (A59230)
2015 Ford F-350...
2019 Felling Trailers 9 Ton 18ft T/A Flatbed Equipment Trailer (A59230)
2019 Felling...
2017 Thompson 32HPU 55kW Towable Trash Pump (A59228)
2017 Thompson...
