welder circuit
/ welder circuit #72
I heard of it happening but never did it either and I have ran a couple of them pretty steady at times. Mostly where it was really too small. Mine was too small the day I got it but had something in mind. Should have got another the same day 2x the size.
But today it's found it's spot and most used welding machine I own.
/ welder circuit #73
i bought a miller 211 probably 10+ years ago and while i am hobby level only, i've never hit the duty cycle. most work i do is 3/16-1/4" with bits and pieces thicker, so most of the time i'm turned down fairly low, so i'd guess i've got closer to 50-80% duty cycle most of the time instead of the worst case 20% that people panic over. the other thing is that i'm usually cutting, fitting, grinding, squaring as i go, so it's weld a little, fit a little, weld a little more, measure a little, square up, weld some more... every now & then i step back and admire my work and take a picture too :D
/ welder circuit #74
I've had two Miller 211s, an older one I bought back in the 90s I think, and one of the new ones that has an inverter power supply. I have used both of them on some pretty long runs, and have never had them shut down. Hard to beat a Miller in my experience.
2010 Ford F-550 4x4 Venturo HT40KX 3 Ton Crane Mechanics Truck (A59230)
2010 Ford F-550...
2018 Ford Explorer AWD SUV (A59231)
2018 Ford Explorer...
2025 GPS Equipment Trailer (A56859)
2025 GPS Equipment...
2014 FORD F-450 XL SUPER DUTY SERVICE TRUCK (A59823)
2014 FORD F-450 XL...
405 (A52706)
405 (A52706)
Wacker Neuson RD12 (A57148)
Wacker Neuson RD12...
