Weld on bucket hooks!
/ Weld on bucket hooks! #1
lutt
Platinum Member
Pocahontas, Arkansas
Kubota ZG 22, John Deere 4200 4wd/ 420 loader, 4 wd,08 polaris 700 ranger crew
In finally got around to welding on my bucket hooks. It's been a while since I've mig welded, so excuse the welds. Also the hooks have been in my basement, that's the reason for the rust. LUTT
Thankyou sir! LUTT
/ Weld on bucket hooks! #4
lutt,
Looks like a pretty good job to me ! ! :2cents: I used the same type hooks on my BX2350 loader, and there has never been a failure to date. I'm sure you will get LOTS of use from them.
Dave
/ Weld on bucket hooks! #5
Good Job Lutt! I use my hooks almost as much as the Bucket.
Thanks guys, I appreciate that! I'm sure I will. I know I've wished I had them own there more than a few times already! LUTT
/ Weld on bucket hooks! #7
I think those welds look pretty good and suspect they'll stay put for a good long time. :thumbsup:
Grab a wire brush then a bit of sanding and paint if you want them to look factory installed!! :thumbsup:
I think those welds look pretty good and suspect they'll stay put for a good long time. :thumbsup: Grab a wire brush then a bit of sanding and paint if you want them to look factory installed!! :thumbsup:
that is on the radar I've for some other work to do to the bucket, but I am gonna paint them. Thanks LUTT
Got to use them this evening, worked well! Had to drag some logs in the clear to buck. LUTT
/ Weld on bucket hooks! #10
Lutt, be careful with using only one hook. Applying weight to only one side of the bucket especially on uneven ground could tip the tractor on its side...Just a heads-up is all....
/ Weld on bucket hooks! #11
Looks pretty darned good to me, I wish I could do that well.
Thanks night force, I was, mostly just testing strength, but ur right. Sometimes we need a reminder. Specially since posting pics can affect first timers. Thanks LUTT
/ Weld on bucket hooks! #14
For one hook pulling, one mounted low, on the back of the bucket is handy ...
/ Weld on bucket hooks! #15
Hooks are good and was thinking a 2x2 recvr in the middle.
Thinking bolt on with support plate underneath.
Low and to the back would be nice. I'm thinking about putting a receiver in on mine also. May do that this weekend. LUTT
/ Weld on bucket hooks! #17
Now you have your hooks now add some D rings. I have chains/steel cable and nylon straps in my lifting arsenal. The D rings work great especially the 7.5k (lift) straps and 3/8" lifting cables .
I added three 12k D rings from a large bond jig my company was scrapping out, inside the bucket. One in the center and the other two in the corners. I used 5/8" dia grade 8 bolts with 3/8" steel plate on the back side to eliminate bending around the bolt holes.
All the above were milspec grade components. The aircraft company I worked for had to scrap out these types of tooling/fixtures after so many cycles. Their over size for my 50 hp blue tractor but being free .... they sure come in handy.
/ Weld on bucket hooks! #18
This is a very close design my dad has on his backhoe loader. His 2 outside hooks are regular chain hooks Then the one in the center is a slip hook. It's not as far back as the one pictured, maybe only 4"s or so. All have worked well
/ Weld on bucket hooks! #19
I used slip hooks in all 3 locations because I prefer to use rope or straps instead of chain, whenever it makes sense.
5/8" polyester double braid is very strong, not too stretchy, somewhat abrasion resistant and a fraction of the weight of an equal length of chain.
If the job dictates that I really need chain, then I use these on the slip hooks:
Good input guys, I still got to get to town and purchase a receiver tube to weld on. I warped the bottom of my bucket the other day also, so looks like some 1/4" replacement steel is in the future! LUTT
CAT D9H 4BBL Multishank Ripper (A68134)
CAT D9H 4BBL...
2017 Jeep Grand Cherokee SUV (A66738)
2017 Jeep Grand...
213130 (A64276)
213130 (A64276)
2018 RAM 5500 FLATBED (A67714)
2018 RAM 5500...
2021 WEILER K560 KNUCKLEBOOM LOADER (A65057)
2021 WEILER K560...
PORTA POTTY (A68842)
