Weld on bucket hooks!
/ Weld on bucket hooks! #1
lutt
Pocahontas, Arkansas
Kubota ZG 22, John Deere 4200 4wd/ 420 loader, 4 wd,08 polaris 700 ranger crew
In finally got around to welding on my bucket hooks. It's been a while since I've mig welded, so excuse the welds. Also the hooks have been in my basement, that's the reason for the rust. LUTT
Thankyou sir! LUTT
/ Weld on bucket hooks! #4
lutt,
Looks like a pretty good job to me ! ! :2cents: I used the same type hooks on my BX2350 loader, and there has never been a failure to date. I'm sure you will get LOTS of use from them.
Dave
/ Weld on bucket hooks! #5
Good Job Lutt! I use my hooks almost as much as the Bucket.
Thanks guys, I appreciate that! I'm sure I will. I know I've wished I had them own there more than a few times already! LUTT
/ Weld on bucket hooks! #7
I think those welds look pretty good and suspect they'll stay put for a good long time. :thumbsup:
Grab a wire brush then a bit of sanding and paint if you want them to look factory installed!! :thumbsup:
I think those welds look pretty good and suspect they'll stay put for a good long time. :thumbsup: Grab a wire brush then a bit of sanding and paint if you want them to look factory installed!! :thumbsup:
that is on the radar I've for some other work to do to the bucket, but I am gonna paint them. Thanks LUTT
Got to use them this evening, worked well! Had to drag some logs in the clear to buck. LUTT
/ Weld on bucket hooks! #10
Lutt, be careful with using only one hook. Applying weight to only one side of the bucket especially on uneven ground could tip the tractor on its side...Just a heads-up is all....
/ Weld on bucket hooks! #11
Looks pretty darned good to me, I wish I could do that well.
Thanks night force, I was, mostly just testing strength, but ur right. Sometimes we need a reminder. Specially since posting pics can affect first timers. Thanks LUTT
/ Weld on bucket hooks! #14
For one hook pulling, one mounted low, on the back of the bucket is handy ...
/ Weld on bucket hooks! #15
Hooks are good and was thinking a 2x2 recvr in the middle.
Thinking bolt on with support plate underneath.
Low and to the back would be nice. I'm thinking about putting a receiver in on mine also. May do that this weekend. LUTT
/ Weld on bucket hooks! #17
Now you have your hooks now add some D rings. I have chains/steel cable and nylon straps in my lifting arsenal. The D rings work great especially the 7.5k (lift) straps and 3/8" lifting cables .
I added three 12k D rings from a large bond jig my company was scrapping out, inside the bucket. One in the center and the other two in the corners. I used 5/8" dia grade 8 bolts with 3/8" steel plate on the back side to eliminate bending around the bolt holes.
All the above were milspec grade components. The aircraft company I worked for had to scrap out these types of tooling/fixtures after so many cycles. Their over size for my 50 hp blue tractor but being free .... they sure come in handy.
/ Weld on bucket hooks! #18
This is a very close design my dad has on his backhoe loader. His 2 outside hooks are regular chain hooks Then the one in the center is a slip hook. It's not as far back as the one pictured, maybe only 4"s or so. All have worked well
/ Weld on bucket hooks! #19
I used slip hooks in all 3 locations because I prefer to use rope or straps instead of chain, whenever it makes sense.
5/8" polyester double braid is very strong, not too stretchy, somewhat abrasion resistant and a fraction of the weight of an equal length of chain.
If the job dictates that I really need chain, then I use these on the slip hooks:
Good input guys, I still got to get to town and purchase a receiver tube to weld on. I warped the bottom of my bucket the other day also, so looks like some 1/4" replacement steel is in the future! LUTT
AGrotk YC-32G Sawmill (A64912)
AGrotk YC-32G...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A63569)
2020 TROXELL...
2015 John Deere 350G Hydraulic Excavator (A64194)
2015 John Deere...
PORTA POTTY (A68842)
2025 Wolverine BC-13-72W 72in Brush Cutter Skid Steer Attachment (A66734)
2025 Wolverine...
CASE TV380 (A67714)
CASE TV380 (A67714)
