Loader weld on brackets for quick attach buckets
/ weld on brackets for quick attach buckets #41
hayspear.com makes 3/8" weld on plates with the upper hooks & BOTH lower pins to fit 300 / 400 & 500 JDQA carriers.
You just have to space the two plates the correct distance apart when welding them on your attachment.
They also sell the hooks & pins separately.
/ weld on brackets for quick attach buckets #42
Found them. Those look perfect for my needs. I'd just have to add a couple of cross pieces to make a frame and a 2" receiver tube to accept a ball-mount and it would be more than strong enough for the front of my "toy tractor."
/ weld on brackets for quick attach buckets #43
I looked at the bolt-on receivers for buckets, and actually had one in my shopping cart, but then I read some reviews and people say they're good for trailers up to ~1k# but will twist or pull off with heavier loads. My trailer is going to be 3500-4000# empty, so I don't think it will do an acceptable job.
Those are the "clamp on" hitches, not bolt on...
/ weld on brackets for quick attach buckets #44
Artillian sells the same type thing also.
/ weld on brackets for quick attach buckets #45
I wasn't aware of those. Now I have a lot of thinking to do!
I also see your post about Artillian carrying the hooks/plates. I'll give them a call when I'm ready to do something, as I appreciate the help that has been provided here.
/ weld on brackets for quick attach buckets #46
I don't think you could go wrong ordering those from Artillian. I've bought a couple of things from them and it's top notch!! Plus Chris (the owner) is great to deal with.
/ weld on brackets for quick attach buckets #47
I don't think you could go wrong ordering those from Artillian ...
Pic or link to the 400/500 plates ??
I couldn't find them :-(
/ weld on brackets for quick attach buckets #49
Thanks
That's a fine looking setup, but attachments having double lower pins sure is NICE when you have a 4 & 5k series tractor :D
My pallet forks, hay spear, 6, 7 & 8ft buckets will fit all 3 of my JD's
/ weld on brackets for quick attach buckets #50
/ weld on brackets for quick attach buckets #51
That's them :D
I think they go on opposite sides, rather than the pic shows them ....
If my memory is workin properly LOL
2010 Chevrolet Camaro Coupe (A66738)
2010 Chevrolet...
2011 Terra Riser 300D-SA Fire Plow Attachment (A61572)
2011 Terra Riser...
2015 (INOPERABLE) FREIGHTLINER CASCADIA (A67714)
2015 (INOPERABLE)...
CASE TV380 (A67714)
CASE TV380 (A67714)
1997 HUBBLER BROS. LOGGING TRAILER (A67714)
1997 HUBBLER BROS...
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
