Loader weld on brackets for quick attach buckets
/ weld on brackets for quick attach buckets #41
hayspear.com makes 3/8" weld on plates with the upper hooks & BOTH lower pins to fit 300 / 400 & 500 JDQA carriers.
You just have to space the two plates the correct distance apart when welding them on your attachment.
They also sell the hooks & pins separately.
/ weld on brackets for quick attach buckets #42
Found them. Those look perfect for my needs. I'd just have to add a couple of cross pieces to make a frame and a 2" receiver tube to accept a ball-mount and it would be more than strong enough for the front of my "toy tractor."
/ weld on brackets for quick attach buckets #43
I looked at the bolt-on receivers for buckets, and actually had one in my shopping cart, but then I read some reviews and people say they're good for trailers up to ~1k# but will twist or pull off with heavier loads. My trailer is going to be 3500-4000# empty, so I don't think it will do an acceptable job.
Those are the "clamp on" hitches, not bolt on...
/ weld on brackets for quick attach buckets #44
Artillian sells the same type thing also.
/ weld on brackets for quick attach buckets #45
I wasn't aware of those. Now I have a lot of thinking to do!
I also see your post about Artillian carrying the hooks/plates. I'll give them a call when I'm ready to do something, as I appreciate the help that has been provided here.
/ weld on brackets for quick attach buckets #46
I don't think you could go wrong ordering those from Artillian. I've bought a couple of things from them and it's top notch!! Plus Chris (the owner) is great to deal with.
/ weld on brackets for quick attach buckets #47
I don't think you could go wrong ordering those from Artillian ...
Pic or link to the 400/500 plates ??
I couldn't find them :-(
/ weld on brackets for quick attach buckets #49
That's a fine looking setup, but attachments having double lower pins sure is NICE when you have a 4 & 5k series tractor :D
My pallet forks, hay spear, 6, 7 & 8ft buckets will fit all 3 of my JD's
/ weld on brackets for quick attach buckets #50
/ weld on brackets for quick attach buckets #51
That's them :D
I think they go on opposite sides, rather than the pic shows them ....
If my memory is workin properly LOL
2012 Komatsu PC200LC-8 Hydraulic Excavator (A64194)
2012 Komatsu...
2012 Volkswagen Passat (A66738)
2012 Volkswagen...
2024 CATERPILLAR 255 SKID STEER (A65056)
2024 CATERPILLAR...
JOHN DEERE 260E (A68134)
JOHN DEERE 260E...
2014 FORD E-SERIES VAN (A67714)
2014 FORD E-SERIES...
2006 FRAC TANK 500BBL WHEELED (A68842)
2006 FRAC TANK...
