ArlyA
Super Star Member
- Joined
- Mar 18, 2016
- Messages
- 14,572
- Tractor
- Outlander1000 6x6, Ego lawn mower and shopping for tractor
I believe it is.is 105 the max string diameter of bump cutter head? i may step up from 95
Strings don't mind rocks and of course, don't spark.95 & 105 are ok for lawn grass, but anything that's grown at all above that needs more.
I inherited a Ryobi 18v cordless trimmer and it works fine around our lawn area, but the old Echo gets the majority of play time with the 155 or the blade because I can't be arsed to regularly go around acres of stuff cleaning up... I just wait for the end of growth and do it once. I've been seriously thinking about getting a couple goats to help... no sparks from hitting rocks at least.
Yes, but they're not as self-directed and self-motivated as goats, either. Then again that's not necessarily a bad thing...Strings don't mind rocks and of course, don't spark.
I have a Ridgid 18 volt weed eater with the 2 speed and I like it as does my wife.Cut from the top down in high stuff. Once it's lower then use a sweeping cut. Cutting at the bottom of tall grass will nearly always result in a wrapped head. I use a DeWalt 20v trimmer. I can do around the house, trees, five sheds, barn and several tractor attachments on one battery charge. It has 2-speeds, but I cut on the low speed to conserve the battery. It's still enough power/speed to cut the wildest weeds.
I was doing that too- walk behind string trimmer but the Briggs blew up. Also have one of the early "Dangerous" DR self propelled brush cutters, that DR quit making because of being sued.Not an answer to your situation, but I only use hand held weed wackers for light duty work. I use a wheeled string trimmer that takes .190 size line. This is more than double the thickness of most hand held trimmers.
My echo wheeled trimmer engine also crapped out after many years. Last year I replaced the engine with a Honda because the rest of the unit is still in great condition.I was doing that too- walk behind string trimmer but the Briggs blew up. Also have one of the early "Dangerous" DR self propelled brush cutters, that DR quit making because of being sued.
It is a darn Good tank of a unit no plastic anywhere on it, and is safe with a responsible operator, but right before the walk behind string trimmer threw a rod the electric start bendix stripped ( Also a Briggs)
I need to get that DR up and running again and maybe try out a predator for the string trimmer.
correct, as i see it now. technique rather than my blaming equip design. i'll see if removing guard makes a difference as wellCut from the top down in high stuff. Once it's lower then use a sweeping cut. Cutting at the bottom of tall grass will nearly always result in a wrapped head. I use a DeWalt 20v trimmer. I can do around the house, trees, five sheds, barn and several tractor attachments on one battery charge. It has 2-speeds, but I cut on the low speed to conserve the battery. It's still enough power/speed to cut the wildest weeds.
You can have mine if you come and get it. I repowered it a few years ago and included electric start. Found a great price for the B&S engine at Surplus Center.I need to get that DR up and running again...
My wheeled trimmer will take 190 size string.95 & 105 are ok for lawn grass, but anything that's grown at all above that needs more.
What percent of people here can use goats? Renta goat? I'd guess it's less that 10%.Yes, but they're not as self-directed and self-motivated as goats, either. Then again that's not necessarily a bad thing...
Goats are a huge business here...goats are great about keeping down green. but hard on landscape plantings, & then there's fencing... the idea of portable containment for goats is interesting, occasionally i see outfits like that for hire. thanks to the replies here, i have a few ideas on how to handle my initial question, regards
takes longer than my old brushcutter that has the 10", but my Stihl FS110 specs that size.Any shortcomings being 8" día?
