weed wacker question
/ weed wacker question
never thought about that one, i'll remove & give it a try, thx
/ weed wacker question #22
We 4 or 5 string capable units. Only ones with guards is the steel wood cutter and when a string bump head is on. They do reduce the green slim debris thrown on you. When done, a bench brush works well to help remove debris from your pants. The pants we use are double fronted and have knee protection installed. 155 string will shot gravel far and take the glass out of your truck. Ask my spouse about that. :ROFLMAO:
/ weed wacker question #23
This blade has been amazingly effective at clearing brush and small saplings on my property. This blade combined with my Stihl trimmer are responsible for clearing a significant amount of area on my property. I’ve probably purchased about 7 of these blades in the past 5 years. My neighbor recently purchased and now uses this blade to clear areas of his property too. I highly recommend it.
Just like another poster mentioned, keep anything you love far away from your work area. This blade sends rocks and debris at lightning speed anywhere and everywhere.
Mike
/ weed wacker question #24
I didn't think anybody would have a more aggressive weed whacker head than I have. But the eye bolts and blades beat mine - hands down.
I have a head that had three, free swinging, nylon blades. I took one new nylon blade to the local welding shop. They made exact copies - out of carbon steel. It will shred anything that I can reach with the whacker.
/ weed wacker question #25
Mike
The problem with steel heads is there small cutting radius. Cut they do but takes forever to cut x amount. Our strings cutting radius is much larger and isn't bothering by rocks or fences.
/ weed wacker question #26
I have one I bought 20 years ago that has an aluminum body and three swinging steel blades. The company went out of business because people got injured and sued. I don't know if it was from thrown debris or blades. I don't use it any more.
I now keep the full guard on the trimmers, especially the 240. It can throw stuff pretty hard. I also wear shin guards. I've used the small cutaway guards and while they let you get closer they also spray the operator with a lot of plant parts, sticks and rocks. It's a little harder to get the full guard to do everything I want but the protection is worth it to me.
Yep, I prefer string heads for the same reason.
/ weed wacker question #27
What is a 240?
/ weed wacker question #28
As an aside there are periods when it is forbidden to use anything spark generating such as a ferris blade… at least here.
This pretty much late season cutting to nylon blades and line.
/ weed wacker question #30
As an aside there are periods when it is forbidden to use anything spark generating such as a Ferris blade… at least here.
Same here in my part of CA once it dries out. If it's not forbidden it's really dumb. Either way I'm not doing it.
I think the same is true in most of the west where there are dry summers and fire danger.
/ weed wacker question #32
I try to keep some of the brush for wildlife cover.
My hope though is to get the rocks and chunks of fallen ash moved so I can use the flail to cut this down without using the brushcutter too often.
The smaller trees, autumn olive and the like don't get damaged by string, but the blade works great.
I use renegade blades for whatever the strings won't take out for now.
It does not bind up even in the tall stiltgrass and cuts though anything up to about 3" without too much work.
yes it is a long time to clear the acre I use it on and some of the unfinished trails, but it works.
EVentually I will also have the trails to where I can get the tractor through, but the dead ash are still falling, still need to remove the bigger rocks and chunks of wood everywhere from shattered ash trees.
/ weed wacker question #33
For more delicate areas I use this head which will take line up to .105 inch. I have a measure set out on my garage work table for the lengths to cut. The ends I have to cut at a 45 angle to feed the line. Because you are working with 6 lines, this chops up the grass in to smaller pieces- less wrap. I don't find steel core line to be any more useful than the Nylon. First thing I do with the bump feed head that came with the new whacker, is to throw it in the trash. :)
/ weed wacker question #34
095 has been my go-to...
Bought several large Tanaka branded spools when a mower shop went out of business...
The Tanaka is good stuff and didn't fuse/melt in the head like others tried.
Just bought some Echo 105 lightning to see how it works.
.105 is the max for my head.
/ weed wacker question #35
Mike
I've been using an Oregon blade that looks pretty much identical -
I'll definitely put it away shortly as the grass is rapidly drying and it'll soon be a fire risk, but it definitely annihilates blackberries, oak seedlings, bunch grass... with the tall grasses depending on how much there is I either sweep back and forth from top to bottom, or I'll just cut it off low and let it fall.
It's really refreshing to be able to use the trimmer for an entire tank of gas without stopping every few minutes to swap strings. We use a 3 string head with cam locks which you jam a string into and it generally holds it (recently replaced the head because the previous one stopped holding the strings), with 0.155 string. That stuff cuts really well but definitely doesn't last very long when given anything other than grass to cut (and I suspect my wife runs it right along concrete walls to get every bit of grass away from it!).
The Oregon blade works great but obviously if you put it in the ground or into rocks it dulls up, but like a brush cutter it'll continue to cut grass even when dull, and it's easy to sharpen. I'll note that even with the blade guard in place, it can really kick rocks - my wife got a big bruise below her knee from hitting a rock.
/ weed wacker question #36
I believe bump heads max string size is 105. I put a Bump head on a few weeks ago so a young fellow can keep our yard while away. Hadn't used it in about 15 years so it was kinda fun. All our normal use and larger string heads are cam lock. Years ago tried some heads where the string freed around things to keep it on and found them terrible to use. Cam lock waaaay better.
/ weed wacker question #37
My best string head is called the Tanka Brain.
It always kept the line optimal without bumping.
Centrifugal force released head to feed the line.
The OEM Echo .105 bump head is ok…
thanks to above posters for equip ideas to avoid weed binding on my bump string head. i'll try removing the guard on the FS250 bicycle handle beast, and my approach technique on tall stemmy fescue. may also step up on the string size. different types of string design is another topic worthy of discussion.
i use blades occasionally but not around landscape trees for obvious reason. once the initial stems are cut, dealing with the blade growth later on is cakewalk
thx again
/ weed wacker question #39
We've tried every "supreme whacko guaranteed" string shape in the book which made little, to no difference. What did was the string diameter and that's why we're hoping to up in size what we use. We do occasionally cut a swamp grass that is fiberry as heck and would need to multi cut its length as the op suggests to get it down.
is 105 the max string diameter of bump cutter head? i may step up from 95, then remove guard
2022 EZ-GO ELITE...
(10) 6 Bar 20' Continuous Fence Panels (A66408)
(10) 6 Bar 20'...
New/Unused Landhonor 78in Rock Bucket with Teeth (A65583)
New/Unused...
PIPEHUNTER HYDRO EXCAVATION TRAILER (A65643)
PIPEHUNTER HYDRO...
2010 Brenner Aluminum 407 T/A Chemical Tanker Trailer (A64194)
2010 Brenner...
2004 Caterpillar 315CL Excavator (A64194)
2004 Caterpillar...
