Weak hydraulics
/ Weak hydraulics #1
Oxfordcar3
Oxford ct
Terramite t5b
Have a 1989 t5b hydraulics are weak and when used bog motor down replaced fluid and filter have 2100 psi at an outrigger any thoughts
Thanks
/ Weak hydraulics #2
Oxfordcar3, I think I have the same machine. Mine is slow and labors the engine when cold. If your problem is when warm I don't know, but hope you will post here when you figure it out so that we will all benefit. What oil did you use?
Good Luck .. Matt
/ Weak hydraulics
Does it warm as well just not as bad I used the recommended engine oil don't remember weight off hand however it was run for unknown amount of time with hydraulic fluid in it will post if I figure it out
/ Weak hydraulics #4
Probily needs new seal kits inside cylinder mine did the same thing although mine is a t3-15 and much older I also have a 14hp kohler single cylinder where you probily have a twin. Another thing you might look at as well is the govenor make sure its set right. I set mine back to factory spec's and only run my terrmater at 1800 rpms and when it bogs down it kicks it up to 3000
Sam
2014 MAC FLAMELESS HEATER TRAILER (A67714)
2014 MAC FLAMELESS...
2018 HINO 338 4X2 S/A 26FT FLATBED (A59912)
2018 HINO 338 4X2...
CATERPILLAR D6N LGP HI-TRACK CRAWLER DOZER (A65053)
CATERPILLAR D6N...
2021 WESTERN STAR 4700 DUMP TRUCK (A67714)
2021 WESTERN STAR...
FOUR PALLETS OF MISC ITEMS (A68842)
FOUR PALLETS OF...
2009 PETERBILT 388 FLATTOP SLEEPER (A67714)
2009 PETERBILT 388...
