Weak hydraulics
/ Weak hydraulics #1
Oxfordcar3
Oxford ct
Terramite t5b
Have a 1989 t5b hydraulics are weak and when used bog motor down replaced fluid and filter have 2100 psi at an outrigger any thoughts
/ Weak hydraulics #2
Oxfordcar3, I think I have the same machine. Mine is slow and labors the engine when cold. If your problem is when warm I don't know, but hope you will post here when you figure it out so that we will all benefit. What oil did you use?
Good Luck .. Matt
/ Weak hydraulics
Does it warm as well just not as bad I used the recommended engine oil don't remember weight off hand however it was run for unknown amount of time with hydraulic fluid in it will post if I figure it out
/ Weak hydraulics #4
Probily needs new seal kits inside cylinder mine did the same thing although mine is a t3-15 and much older I also have a 14hp kohler single cylinder where you probily have a twin. Another thing you might look at as well is the govenor make sure its set right. I set mine back to factory spec's and only run my terrmater at 1800 rpms and when it bogs down it kicks it up to 3000
Sam
213088 (A64276)
213088 (A64276)
2017 Caterpillar DP70N1 15,500lb. Straight Mast Diesel Forklift (A64194)
2017 Caterpillar...
2022 Ford F-150 4x4 Crew Cab Pickup Truck (A66736)
2022 Ford F-150...
KAWASAKI 95ZIII Radiator (A68134)
KAWASAKI 95ZIII...
ROANOKE S/A LOOSE LEAF TRAILER (A63291)
ROANOKE S/A LOOSE...
32ft T/A Flatbed Tag Trailer (A66736)
32ft T/A Flatbed...
