Weak FEL loader LA352
/ Weak FEL loader LA352 #1
53gravely
NJ/VT
Kubota 7610 HSD
I have a 2005 B7610HSD w/ LA352 FEL (500 hrs) that has gotten weak on the lift arms in both directions.
First, over the last couple months, the float function got hoaky….will pop out of the detent very easily (not sure this is related). Recently, the bucket won’t lift more that 200lbs above 18” off the ground, nor does it have the downforce to lift the front wheels off the ground.
The curl/dump function seems fine….i can lift the front wheels off the ground with the dump function.
With the timing of the float issue and the problem with just the lift arm function, I’m guessing it’s the up/down circuit in the control valve. Am I on the right track?
How hard are these to rebuild without a shop full of tools for hydraulics?
Thanks!
/ Weak FEL loader LA352 #2
Check the position of your three point lever. If it's in the full up position it can cause the hydraulics to go into bypass mode robbing power from any other hydraulic accessories. If that's your problem the solution is to move the three point lever a bit off of full up. If that does it your rock shaft needs adjusted.
/ Weak FEL loader LA352 #3
There is nothing to rebuild inside the valve but the centering spring and detent assembly under the cap or cover can fill with crud and not allow the spool to move properly.
Also double check linkage from joystick to the valve spool to confirm it is working properly.
2005 Peterbilt 378 Day Cab w/ Wetline 834826 (A62613)
2005 Peterbilt 378...
Bulk Lot - Used Steel Transfer Pipe & Fittings (Chuck Pipe) (A63689)
Bulk Lot - Used...
2023 Top Air ATV 200 Gallon Pull Type Sprayer with 30ft Booms (A63688)
2023 Top Air ATV...
New/Unused CFG Industrial NT18K Mini Excavator (A65579)
New/Unused CFG...
2006 Snorkel AB50J 50ft 4x4 Articulating Boom Lift (A61572)
2006 Snorkel AB50J...
2018 Lincoln MKT Town Car AWD SUV (A61574)
2018 Lincoln MKT...
