Water tank for a cabin.
   / Water tank for a cabin. #31
I use a couple of the 300 gallon totes that had frocuse in them cost $75 or 80 each one is beside my cabin plumbed to a pitcher pump by sink
The other is on a trailer to fetch water at a spring about 5 miles away. we use this for washing dishes ect I put about 1 quart of bleach in at each fill we have an out house for the other business.
tom
   / Water tank for a cabin. #32
tom
   / Water tank for a cabin. #33
a standard cistern trick ...consider homemade diverter valve operated by weight of full "bucket" ...it has to fill before any water is diverted into holding tank ...roof is washed before any water is stored
   / Water tank for a cabin. #34
Trying to decide what is the best size tank I should buy. Should I buy a 225 gallon or a 502 gallon tank? My plumping is 3/4 plastic main and then reduced to 1/2 inch at Toliet and shower and washing machine. Wonder what size demand pump will I need and it will be 120 volt pump. My local farm supply is where I'm going to buy the tank.
Thanks, John
Thanks, John
   / Water tank for a cabin. #37
If your going to use a pump to supply the water there is no reason to elavate the storage tank, you could even bury it. I think this goes without saying but be sure to get a tank that is approved for this purpose (food grade). An RV demand pump would work, but you could use a common jet pump for your situation too, heck wire it 240vac if you want. Buy the smallest and cheepest one.
My advise, If your soil conditions allow it you may want to consider putting in a shallow, driven, 1 1/4" well (commonly called a "sand-point" in my neck of the woods). Its not difficult nor expensive and no more hauling h2o! Good luck.
   / Water tank for a cabin. #38
Tank will be installed in a pole barn on a concrete floor.
John
John
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
2016 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2016 Ford F-150...
Willmar 4550 Wrangler Articulating Loader (A56438)
Willmar 4550...
2013 Nissan Rouge SUV (A56859)
2013 Nissan Rouge...
2005 MACK TRI AXLE DUMP TRUCK (A52707)
2005 MACK TRI AXLE...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
