water pump
   / water pump #1
easley man
easley sc
lb1914
Hi i have a Kioti 1914 and it is leaking from
the fan what could it be?
   / water pump #7
I assume you have antifreeze flying. Probably the pump shaft seal. Usually when they go bad, the shaft bearing is starting to go. There is a chance that the gasket from the pump to the block is leaking but the fan will just blow the antifreeze back on the block and not pick it up and sling it around. Some pumps can be rebuilt and others you just replace the entire pump.
1991 HEIL FUEL TRANSPORT TRAILER (A52472)
1991 HEIL FUEL...
2020 Peterbilt 520 T/A Cab and Chassis Truck (A51692)
2020 Peterbilt 520...
2009 Chevrolet Trail Blazer SUV (A51694)
2009 Chevrolet...
RHINO LOT NUMBER 64 (A53084)
RHINO LOT NUMBER...
2006 GAYLEAN  130BBL (A52472)
2006 GAYLEAN...
4"x8' Treated Post, 36 Piece Bundle (A52384)
4"x8' Treated...
