Oil & Fuel Water in fuel
/ Water in fuel #1
edmartin
SC, USA
Yanmar YM2000
Does anyone have any knowledge or method for removing water from diesel fuel other than buying a large capacity tank and filter. I've tried all the local outlets using "red" fuel and get water in all of them.
/ Water in fuel #2
The fuel will float on top of the water if it is not agitated. I would let stand, siphon the top layer of fuel and separate from the original container. I would only do this if this is allot of fresh fuel that is slightly contaminated.
Mark
/ Water in fuel #4
Any container with a spigot on the bottom will drain off the water if allowed to sit long enough. I use a 55 gal. drum and pump off the top.
/ Water in fuel #5
My last load of fuel from a big supplier was loaded with water.
I use power service as well as biocides for tank treatments.
My suggestion is to have a water drain tap at the lowest point of the tank if you do bulk storage, and use a filtered breather as oposed to an 'open' tank breather.
For in the can / in tank water.. if it is a large amount, I'd crack a fuel line and purge it.
Many tractors have both sediment bowls with water dains, and some even have fuel filters with water drains... make use of them.. often!
Soundguy
/ Water in fuel #6
I find it easiest to syphon off the water. use a steel tube (3/8' line) to get to the bottom of the tank, with a rubber hose attached to that. Tip the tank a little if necessary. Just run the syphon until you get clear diesel, and you're back in business. Add a little gas line antifreeze for insurance if you like.
Richard.
2017 YALE VERACITOR 50VX STRAIGHT MAST FORKLIFT (A63276)
2017 YALE...
New/Unused Wolverine 72in Tiller (A65583)
New/Unused...
100 Gal L Fuel Tank (A65643)
100 Gal L Fuel...
2026 NORSTAR IRONBULL T/A 25FT GOOSENECK TRAILER (A59914)
2026 NORSTAR...
Westendorf 8' Loader Bucket (A66408)
Westendorf 8'...
2018 Freightliner M2 106 20Ft. Reefer Box Truck (A64194)
2018 Freightliner...
