Water Filter Splits
/ Water Filter Splits #1
Alan W.
Kentucky
Kubota L3650 & Bobcat 763G & Craftsman DGS6500
Yesterday after lunch I discovered that my water filter had split and was spraying into my basement. I had installed it in 98 when the house was built.
While I made a run to Lowes my son set up fans and used the shop vac to clean up.
This is on the unfinished side luckily.
Dont know if there is a lifespan on these or mine was a freak accident.
House is plumbed with CPVC and it is getting brittle. Could not cut it without it shattering with my cutter so I had to saw it carefully. Ran PEX from the inlet to the filter. Will eventually replace whole house with PEX.
/ Water Filter Splits #2
I would say 26 years is a good run for anything made from plastic. I replace mine when the shutoff stops working, or gets hard to turn, probably in the 10 - 12 year range. Fortunately my plumbing is all copper and my filters are in the basement utility room which has a floor drain. So far no catastrophic failures. I see many of these installed under the kitchen sink. A failure there would be a disaster for my wood floors.
/ Water Filter Splits #3
I have installed one of these under each sink in house. It already saved my butt when instahot unit failed in basement wetbar. I was alerted right away to something that i probably would not have noticed for days.
i also have sensors in freezers, refrigerator, wifes greenhouse and garden sheds that monitor temp and humidity. One alerted me to a door left open in garage freezer and saved a bunch of frozen meats.
A few sensors would probably be a good idea.
2019 Peterbilt 520 Heil DuraPack Python 28Yd Side Loader Garbage Truck (A68183)
2019 Peterbilt 520...
2013 Audi Q5 AWD SUV (A66738)
2013 Audi Q5 AWD...
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
Unused 2022 Ideal BB4LD 48in. Box Blade Tractor Attachment (A66734)
Unused 2022 Ideal...
2006 Hummer H3 4x4 SUV (A66738)
2006 Hummer H3 4x4...
Ari-Hetra HDML-8 15,000lb Four Post Auto Lift (A64553)
Ari-Hetra HDML-8...
