Wash Your Tractor?
/ Wash Your Tractor? #41
I wash my tractor 2-3 times per year and wax it then too with the air powered buffer. Makes the paint as smooth as glass with 3M waxes. At the ol JD store I wash everything as that is the main part of my work and it takes upwards of 8 hours to wash a combine and it is important to get the moldy corn out of the hopper and any dust and other debris around the outside. I do pressure wash & soap the combines and tractors trying not to get the starter and other vital components wet.
/ Wash Your Tractor? #43
2 1/2 years and I've not washed it yet.
I have enough trouble finding time to do the things it needs (check wheel torque, air pressure, grease the fittings, check oil and hydro fluid levels).
Why would I want to take extra time to do something that will certainly cause more harm than good. Ever look at a BX deck? It looks like it is designed to funnel water straight to the bearings!
Water and machines are essentially enemys. Oil and grease are machine freindly. Dirt is nuetral (except where is collects to a large amount and can attract moisture).
But hey, they are expensive so I can understand a guy wanting them to shine. I just think that the potential water born problems outweigh the desire for me to see clean orange.
/ Wash Your Tractor? #44
I'm just curious... I wonder if these same reasons for not washing a tractor also apply to the family car? /forums/images/graemlins/confused.gif
/ Wash Your Tractor? #45
I powerwash mine after heavy use. I will admit that I like the looks of a clean tractor not to mention it just feels new when it is clean. /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
PJ
/ Wash Your Tractor? #46
A car is completely different than a tractor. The engine, transmission, electrical, etc. is right out there in the open on a tractor. On a car all you are washing is the sheet metal. Unless you open the hood and power wash it the engine will rarely get water to it. The wheels protect the bearings and such as well. Not the same at all for sure.
/ Wash Your Tractor? #47
Yup, wash and wax it every chance I get. I do it right out front for all the neighbors to see. they already think I'm nuts, so why not reinforce it??? /forums/images/graemlins/grin.gif
I figger after spending over $12,000 it should look nice. I also wash and wax my Accord every chance I get too.
One of the benefits of all this cleaning and waxing is that you learn the machine inside and out, and you find any little thing that may be about to give you problems.
/ Wash Your Tractor? #48
I wash as needed, about once a month. Typically, this is also around the same time as greasing is done, the wash comes first, then the chamois hand drying, then the grease. I do use my air gun to clean inbetween washings and carefully under the hood. I wax about once a year.
Jerry
/ Wash Your Tractor? #49
</font><font color="blue" class="small">( A car is completely different than a tractor. The engine, transmission, electrical, etc. is right out there in the open on a tractor. On a car all you are washing is the sheet metal. Unless you open the hood and power wash it the engine will rarely get water to it. The wheels protect the bearings and such as well. Not the same at all for sure. )</font>
EXACTAMUNDO!!!
BTW - I really don't wash my cars all that often either, but I try to get to them as often as I can 6-10 times a year.
/ Wash Your Tractor? #50
I'm with Bigun on this one. I rarely even rinse my tractor (no pressure washer /forums/images/graemlins/frown.gif) but I do use compressed air on all of my equipment quite frequently. It works great to blow out the dust and crud that accumulates all over the place. And no worries about rust, etc.
Now, I probably should wash and wax my tractor once a year, but who has time? I spent the better part of two days just changing the oil in all my toys . . . er tools.
iDrive TDS-2010H...
2014 Ford F-150 4x4 Ext. Cab Pickup Truck (A59230)
2014 Ford F-150...
2010 Toyota Highlander SUV (A59231)
2010 Toyota...
NEW HOLLAND T4.75 POWERSTAR TRACTOR (A62130)
NEW HOLLAND T4.75...
2010 Ford F-550 4x4 Venturo HT40KX 3 Ton Crane Mechanics Truck (A59230)
2010 Ford F-550...
Brock 48'x16' Flat Bottom Grain Storage Tank (A57148)
Brock 48'x16' Flat...
