Warning light guards.
/ Warning light guards. #1
chevy
Platinum Member
East Central, Indiana
Kioti CK3510SE HST, John Deere X739
I searched for warning light guards to put on my CK3510SE. Dealer said that Kioti did not have any.
I found some on ebay, but they are mounted to the tractor using only the light.
Also they were only 2" deep. My warning lights are over 2".
I decided to make my own out of 1/8" X 3" flat steel that bolt to the tractor using the light & light mounding bracket.
/ Warning light guards. #2
You've got me thinking. It's probably a miracle that I haven't broken mine yet.
/ Warning light guards. #3
I like the looks...good job. :thumbsup:
/ Warning light guards. #4
Hope you don't mind, I essentially copied your design, and am in the middle of fabricating a pair of these. I've got 100hrs on my ck3510se, and I've broken one of these lights 3 times already. Hope mine look as good as your when I'm finished and paint them. Thanks for the idea!
I do not mind at all. I posted then to help others.
/ Warning light guards. #6
Looks nice. Like it was original equipment.
Dealer here suggested moving them to the mounting holes on the fenders. Haven't done it yet.
/ Warning light guards. #7
Here's how mine turned out. I wanted to add some kind of additional protection front and back...I used some 3/16 rod, but I ran out. Gonna grab another stick sometime, and add a vertical and horizontal piece inside the diamond, if that makes sense. The rods on the back of the guard are welded in place, the front is hinged, to allow for bulb changes. Pretty happy with how they turned out, but after painting it was obvious I should've spent more time cleaning up my welds and whatnot.
Looks good. I like the added protection.
/ Warning light guards. #9
I like the design though I thought I might use expanded steel instead of the rod to give a bit more protection. Is that a tool box you have mounted a bit lower? Could you post a couple of pics of that or point me to the thread if you have already post pictures.
Thanks
Rancho
CK20 HST
/ Warning light guards. #10
Thanks
Rancho
CK20 HST
Yeah, I'm gonna grab some more rod one of these days, and add a few more bars for added protection. The toolbox is just the standard little one that comes with a ck3510se. It's pretty small, but enough to keep a couple wrenches and a handful of different pins and whatnot. I can take a pic or two when I get home.
/ Warning light guards. #11
Here are mine. Made from a piece of flat plate with appropriate holes drilled and some U-bolts bought at a local hardware store.guard5.JPGGuard1.JPGguard2.JPGguard3.JPG
Mine had to protect the base of the light and not just the light. I tore the entire assemble off twice before making the guard. Cost me less then $80.
The bolts holding the guard on replaced the pins that held the roll bar up. Hmmmm…..looking at my pictures I wonder if I should have used Grade 8 bolts.
Oh well.
RSKY
/ Warning light guards. #12
I like the simplicity of those. Does it prevent you from folding your rops down though?
/ Warning light guards. #13
I would have to remove the bolts to fold it. BUT from the time I purchased the tractor I have never had a reason to do so. I like the looks of some of the other guards shown on this thread but in my situation I would tear the light AND the guard off. So far so good with these. These pictures are a few years old. The guards now have lost a bit of paint but have server their purpose well.
I couldn't fold my ROPS without taking the guards and a couple other things off as I also have a fire extinguisher mounted. Also made a holder for the ball and hitch that fit into the receiver on top of the bucket. It would have to be removed also.
RSKY
Kubota L4802 DT LA766 Backhoe (A63688)
Kubota L4802 DT...
LOOK! (A63109)
LOOK! (A63109)
Caterpillar 600 Series Tractor Parts Manuals (A63117)
Caterpillar 600...
2021 Kubota MX6000 (A62177)
2021 Kubota MX6000...
2019 UTILITY VS2DX 53' X 102" T/A VAN TRAILER (A59912)
2019 UTILITY VS2DX...
2017 Ford Escape SUV (A61574)
2017 Ford Escape...
