Warn 2.5ci wench problem
/ Warn 2.5ci wench problem #22
I'm betting it depends on what model Warn you are talking about, some are made cheaper than others.
I have Warn, HF, Ramsey and a few others, and they aren't all from china.
SR
/ Warn 2.5ci wench problem #24
Should you buy a little more winch than your task calls for, then the winch may work a little less in the world of straining.
Regardless of where it may or not be manufactured.
/ Warn 2.5ci wench problem #25
The range of winches on the market is very broad. The bottom end isn't worth bolting on. The top end is hard to justify.
My uses of a winch are offroad. I only buy top end.
With winches, you get what you pay for.
I burned up a Warn 2,500 lb winch on a side by side. It was under warranty. Shipped it to Warn and they rebuilt it. No charge. The side by side now has a Warn 4,500 lb winch.
Good luck with your repair.
/ Warn 2.5ci wench problem #26
The biggest cause of failure for a winch is getting it wet or muddy and never running it in and out. I have the cheapest winch you could buy at HF, put on my atv over 10 years ago. that winch has been underwater at least 100 times. I make sure to run it in and out a couple times a season. Still works flawless.
/ Warn 2.5ci wench problem #27
Wow, how does your ATV handle that?
/ Warn 2.5ci wench problem #28
fine, weighs 500, rated 1500, snatch block if needed, but haven't. prolly 30-40 hard pulls. doesn't get a ton of use, but it goes underwater a whole lot back in the day.
/ Warn 2.5ci wench problem #29
The under water part was what I wondered about.
/ Warn 2.5ci wench problem #32
Well to get the winch under water don't you have to get the lower half of the ATV under water?
I have floated my atv multiple times. right up to the air snorkels. some of the trails I did, required it.
3 bearings, couple seals, drum to disk brake conversion, was about it.
2002 Honda Rancher ES. 7k miles on it.
/ Warn 2.5ci wench problem #33
Cool. I've never had an ATV that would float.
/ Warn 2.5ci wench problem #34
did you actually try? they get very tippy, but almost all of them would. the only atv's with issues was generally belt cvt, as the vents for the belt were too low. you pretty much only have a foot above water. exhaust etc was about a foot under, and if you let off the throttle. you were done.
/ Warn 2.5ci wench problem #35
I can honestly say I've never tried to "float" any of my ATVs. I have witnessed a few enter deep water without knowing it was coming. None of them "floated" without the operator trying desperately to hold them up. First thing they want to do is roll over on their back since the flotation is the tires.
But if you have successfully floated your ATV 100 times and it's survived, kudos.
/ Warn 2.5ci wench problem #36
no maybe about 10 times I floated it, but the atv winch routinely goes underwater for river crossings/ ditches etc, we live in rivers and forest up here.
/ Warn 2.5ci wench problem #37
Cool.
/ Warn 2.5ci wench problem #39
2017 TROXELL 150 BBL ALUMINUM VACUUM TRAILER (A65643)
2017 TROXELL 150...
2021 ASV RT-120 FORESTRY SKID STEER (A65053)
2021 ASV RT-120...
Landhero LDH-TWP80, Gasoline Water Pump (A62679)
Landhero...
Deutz D 2011 L03 Engine, 3-Cylinder Diesel (A63689)
Deutz D 2011 L03...
8ft Rotary Cutter (A65579)
8ft Rotary Cutter...
(50) Traffic Cones (A64127)
(50) Traffic Cones...
