Warming hydraulics
/ Warming hydraulics #21
The relief valves are designed to do this every time you fully extend a boom, cylinder, or your steering wheel. It's not hard on them at all.
/ Warming hydraulics #22
I hear a bit of whine too, but I think that's normal noise from the system.
As for sluggishness, that might be a factor of the grease being stiffer from the cold, as well as greater friction in the joints due to contraction of the metal from the cold. I'm not sure how much physical tolerance they design into those moving parts over extreme temperature ranges.
/ Warming hydraulics #23
If a fella was to do so, isn't that kinda hard on the relief valves or no?
BarnieTrk
Nope, you use them all the time you likely just don't realize it. Albeit in short bursts. The only harm can come from overheating the fluid, which will take a while, and youre trying to heat up the oil anyway right?
7' Disc (A62613)
7' Disc (A62613)
NEW Wolverine ADB-13-1218R, Skid Steer Auger (A62679)
NEW Wolverine...
150 GALLON FUEL TANKS (A65643)
150 GALLON FUEL...
Peanut Wagon (A64127)
2001 Sterling Single Axle Dump Truck (A62613)
2001 Sterling...
213087 (A64276)
213087 (A64276)
