Wanting to "cut" a slot in the ground
   / Wanting to "cut" a slot in the ground #32
I've thought about something like this based on the 3PT auger I already have. I imagine a modified frame turning the auger to the side and lowering it a bit, and perhaps a small variety of rotary attachments and shaft extensions to replace the auger bit.
   / Wanting to "cut" a slot in the ground #34
I had great success with the gas powered edger and might not continue with the coulter project.....but I did grab it out of storage this weekend and, well, it might still happen.
   / Wanting to "cut" a slot in the ground #35
I have a shank mounted to a ssga plate for ripping trenches across my driveway as water cuts.
This has a cultivator sweep added to a ripper shank as I wanted a V shaped ditch. Without the sweep it was just a narrow slice.
   / Wanting to "cut" a slot in the ground #36
I know our OP solved his problem; but for anyone in the future. Off set single 3 point disc, with weight basket
2016 Freightliner M2 106 AWD Terex Hi-Ranger 5TC55 55ft. Insulated Material Handling Bucket Truck (A55973)
2016 Freightliner...
Bogballe L20W Plus (A53317)
Bogballe L20W Plus...
2006 Crimson Spartan Fire 105ft. Quint Ladder Aerial Truck (A55973)
2006 Crimson...
2010 John Deere TX Gator 4x4 Utility Cart (A55973)
2010 John Deere TX...
2012 Ford F-550 (A55973)
2012 Ford F-550...
2015 Ford F-550 (A55973)
2015 Ford F-550...
