Wanting to "cut" a slot in the ground
   / Wanting to "cut" a slot in the ground #31
Just did this myself. Rented a Bluebird edger from local rental yard. Most of my edging was going into packed gravel and money well spent!
That's a good option. (y)
   / Wanting to "cut" a slot in the ground #32
I've thought about something like this based on the 3PT auger I already have. I imagine a modified frame turning the auger to the side and lowering it a bit, and perhaps a small variety of rotary attachments and shaft extensions to replace the auger bit.
   / Wanting to "cut" a slot in the ground #34
I had great success with the gas powered edger and might not continue with the coulter project.....but I did grab it out of storage this weekend and, well, it might still happen.
   / Wanting to "cut" a slot in the ground #35
I have a shank mounted to a ssga plate for ripping trenches across my driveway as water cuts.
This has a cultivator sweep added to a ripper shank as I wanted a V shaped ditch. Without the sweep it was just a narrow slice.
   / Wanting to "cut" a slot in the ground #36
I know our OP solved his problem; but for anyone in the future. Off set single 3 point disc, with weight basket
2020 DRAGON ESP...
New/Unused Quick Attach Wood Chipper (A57454)
New/Unused Quick...
2017 Ford F-250 Pickup Truck w/ Liftgate (A56858)
2017 Ford F-250...
(2) METAL & WOOD STORAGE RACKS (A52708)
(2) METAL & WOOD...
110 GALLON FUEL TANK (A52708)
110 GALLON FUEL...
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A55973)
2019 International...
