Wanting to buy new tractor
   / Wanting to buy new tractor #11
Is it safe to say you are looking for a modern, more comfortable, cabbed, HST, replacement for your FarmTrac 665DT?
Depending on what impliments you have/had on the gear Farmtrac, you might want/need more HP out of an HST, to run the same impliments. With 60 engine/52 PTO; the Massey 60hp HST is turning out 45 hp at the PTO (power shuttle does 47hp at the PTO). Most impliments will be fine, but if you were on the edge before (pto power wise), you might need to step upto a 70hp?
   / Wanting to buy new tractor #12
The dealer I got my Branson from is now a TYM and Zetor I just saw one of his ads this morning he's just trying to tempt me;
Zetor Proxima P100 for about $83,000 looks very nice, power shuttle and nice roomy cab.
   / Wanting to buy new tractor #13
The MX6000 puts out a gross 63 hp and 52 pto hp. That ought to run most implements he has.
   / Wanting to buy new tractor #14
2 years ago I bought a used 2018 Kioti RX7320 with 160 hours on it for $39,000. Cab, loader, and 3 remotes. Not hydrostatic, but shuttle with an awesome transmission. The only time you need to push the clutch in is when starting the tractor and changing ranges. Other than that, you use the shuttle to change forward/reverse and press a button on the shifter to switch gears. It will also start out in any gear that you have it in, so you rarely need to change gears if you know what you want to be in when doing whatever you intend to do. I've had zero issues with it.
   / Wanting to buy new tractor #15
Maybe Deere 5060e? Nice size utility tractor.
   / Wanting to buy new tractor #16
OP: whatever tractor you look at, realize a spin around the dealers lot is a poor simulation of field tasks. good luck
   / Wanting to buy new tractor #17
If ;you have a Yanmar dealer near by you
might want to check this one out Yanmar YT359C The transmission is like having a standard and hydro all in one also possible
to get up to a $4500 discount and 10 year
drivetrain warranty
willy
   / Wanting to buy new tractor #18
With cab machines, pay particular attention to blind spots, and how You see, can you see bucket corners, ends of 3 point arms, outside corners of a 7 (or 8) foot rear impliment, how about upward front-left/right. Spec sheets can't really show visibility, and seeing bucket corners is important, as well as lower lift ends.
Also, with a cab, it needs to have outside fender mounted 3 point controls, or you will be in/out and cussing every time you hook up an impliment. Don't know that outside rear PTO switch matters, but I guess it's important for certain activities/impliments.
   / Wanting to buy new tractor #19
Look for approximately a 60hp, 4 x 4 Loader, rear remotes, and cab. Looking for suggestions and what it cost. Your suggestions are appreciated.
Look at the dealers in your area. Parts and service make a huge difference when looking.
   / Wanting to buy new tractor #20
I have a Kubota L5740 4x4 Cab with a Front End Loader. Hydrostatic Transmission. 3rd function. Quick Connect Loader and Bucket. 1600 hrs.$36,500
1998 INTERNATIONAL 9100 WATER TRUCK (INOPERABLE) (A55745)
1998 INTERNATIONAL...
1997 Ford Tandem Dump Truck (A59814)
1997 Ford Tandem...
5' ROTARY MOWER (A52706)
5' ROTARY MOWER...
PARTS ONLY - Has Title - 2023 Ram 1500 Classic Pickup Truck - Hemi 5.7L - Automatic Transmission (A56438)
PARTS ONLY - Has...
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
2020 Bobcat MT85 (A53317)
2020 Bobcat MT85...
