Wanting to buy new tractor
   / Wanting to buy new tractor #1
I Piddle
Western Maryland
Farmtrac 665 DTC
Look for approximately a 60hp, 4 x 4 Loader, rear remotes, and cab. Looking for suggestions and what it cost. Your suggestions are appreciated.
   / Wanting to buy new tractor #2
You might tell us what dealers are nearby and your budget. There are a lot of choices in with that spec.
I forgot to mention I also want Hydrostatic Trans. I have TYM, LS, Branson, Kioti, John Deere, and New Holland. I would consider up to $60 K. But I may come to my come to my senses on price.
   / Wanting to buy new tractor #4
And tell how and where you will use it for the most relative answer. (y)
I have 265 acres most is wooded, with 30 acres of farmland some hillside pasture fields. No longer have livestock on farm, just make hay. Need something to keep pasture fields from growing up maintaining roads and trees along the field/woods line from overtaking the fields.
   / Wanting to buy new tractor #6
Are you in good health? you want the tractor controls make it easier to use...visit has many dealers you can maybe test spin if you can.
Besides mower what other attachments...grapple,forks,back blade,.
Tire thread you're considering and will spacers be needed if tire chains are used.
   / Wanting to buy new tractor #7
Branson / TYM - their biggest HST model is 55HP. Anything bigger is either shuttle shift or Power shuttle. so that may rule them out for you.
I really like the power shuttle they make, I've driven the T654 and T754 and they are nice tractors. Deutz engines in both of those.
   / Wanting to buy new tractor #8
My MX6000 is 60hp with HST. It also is available with a cab. But you said that you don’t have Kubota nearby?
   / Wanting to buy new tractor #9
Do you have Massey? I think a Massey 2860M would be worth a look. I would seriously consider the Power Shuttle, even if you go into it thinking you want the HST, it's worth a test drive. Should fit nicely into your budget, and seems to be a heck of a nicely put together machine
   / Wanting to buy new tractor #10
The 2860M also comes in HST flavor too. Looks like cab, 4x4, loader, HST, new, is between $46k and 52k. That should run 8ft cutter
2023 Ford F-150 Crew Cab Pickup Truck (A59230)
2023 Ford F-150...
2011 Ford Escape SUV (A59231)
2011 Ford Escape...
2014 Toro Z-Master 6000 Series 60in Zero Turn Commercial Mower (A59228)
2014 Toro Z-Master...
Rooster Weathervane (A59231)
Rooster...
2018 CATERPILLAR 242D SKID STEER (A60429)
2018 CATERPILLAR...
1987 CATERPILLAR D6H HIGH TRACK CRAWLER DOZER (A59823)
1987 CATERPILLAR...
