want to build a log splitter, need advice
   / want to build a log splitter, need advice #1
chad fitz
Fennimore, wi
460 utility IH
Hello, Im new here, it looks like there is alot of knowledge on this forum. Have some questions. Im going to build myown log splitter for next year and have several questions. As of now I think i want to copy or come close to the iron oak splitter with adjustable weadge and log lift. Like i said i will have alot of questions but will ask only a few at a time to help keep things organized.
Question. cylinder size, motor hp, pump = tonage and cylcle time, i know one equals the other but dont understand the calculations which means i dont know if i change A, this will happen.
Currently condidering the following
4" x 24" cylinder with 1 3/4" or 2" rod. Iron and oak uses 3" rod, what difference does the rod make? If i end up with a 4 1/2 or 5" cylinder, whqat happens? slower cycle, more tonage? How much slower? how much more tonage?
2 stage 22 gpm pump, is there a "right" size hydrualic tank?? they use 14 gallon. Is there a rule of thumb for gpm = oil capacity?
11hp motor, they use honda, i will likely not be able to affford honda, so will any 11hp motor work the same. If i end up with a higher hp motor what will happen? speed, tonage, go up. will i need different pump etc??
Thanks for any and all help, i have the fabrication ability but not the knowledge to know what parts to get. My plan is to gather all the parts over the next few months in the hope of saving money.
chad
   / want to build a log splitter, need advice #2
Not sure if you know it or not but there is a search function at the top of the page.. You might try it here and in hydrualic section too.. Good luck with your project..
   / want to build a log splitter, need advice #3
Welcome to TBN ! Might also want to do a TBN search under home made LS tons of info on here from members who have built them.
Good pic's too !
Boone
thanks for the links, i will take a look at them and then likely have more questions down the road.
thanks again chad
   / want to build a log splitter, need advice #6
Chad, you'll be fine with a 4" cylinder the bigger you go the more tonnage but slower cycle times. I rebuilt a splitter and with a 4" cylinder running 3000psi I havent found a log it wouldnt split. The bigger the rod the better for cycle time and strength, match the motor to the pump bigger is only going to suck more gas the pump will only pump what it can. As far as oil capacity they recommend 1 gallon of fluid for every gpm so 22 gals for that pump. Good luck with the build you'll learn alot!
   / want to build a log splitter, need advice #7
Motor gets sized to the pump. Going with a bigger motor only burns more gas, but dont increase speed or power, cause those are determined by the pump. You only need a motor big enough to run the pump up to is max pressure, anything above that is a waste.
I have heard two rules of thumb on sizing tanks for a 2-stage pump.
1. 2.5-3x's the high pressure flow. On a 22gpm, the high pressure is like 6gpm. So that makes you need a 15-18gallon tank.
2. Half of the low pressure flow. Which is 22gpm on a 22gpm pump. That would call out for 11. Iron an oak is tried and true, if they use 14 gallons with a 22gpm pump, stick with that. But is their resivoir actually 14gallon???or is that total system capacity???
Either way, on the tank, you are splitting hairs. If it were mine, I'd probabally just make it an even 15 gallons That way, 3 buckes of oil works out perfectally.
Cylinder size:
As cylinder size goes up, speed goes down and force goes up. At 3000psi, the following:
Cylinder.............extend time...................tonnage
4x24..................3.6 sec..........................18.84
4.5x24................4.5sec..........................23.85
5x24..................5.6 sec...........................29.5
A 4" cylinder will slit mostly EVERYTHING with a single wedge. But with you wanting a 4 or 6 way, you may find some things it wont go through. I'd opt for the 4.5" if it were mine. Thats a good balance of speed and power.
As to the larger rod, yes it makes it stronger, but a 2" rod on a 4 or 4.5" cylinder is pleanty strong so I doubt thats why they did it. Rather it makes the return cycle alot quicker since the rod occupies space in that side of the cylinder, the bigger it is, the less fluid it takes to fill up and fully retract.
with a 4.5" cylinder, going from a 2" rod to a 3" rod shaves a full second off the cycle time. (3.6 sec vs 2.5 sec). A full second when splitting wood for production is huge.
And any 11HP motor should work just fine. It dont matter wether is honda, briggs, kohler, or anything else, 11hp is 11hp. Just be sure to use a lovejoy coupling and not a ridgid shaft to shaft coupler
And as others have mentioned, do a search on this site. These questions have been answered numerous times in the past, and you can see the end result of several here who have done what you are wanting.
   / want to build a log splitter, need advice #8
Hey Chad,
I don't know your age or skill level, but making a splitter is a fun and rewarding project! Every time that you use it you will be rewarded with the feeling of accomplishment !!! I built one about 25 years ago and am still using it today !!! I was a Technical Education high school teacher and I built it over several months after school hours. Got to take the perks when you can get them...LOL !!!! I had complete use of the metal shop and that was VERY helpful. One of the best machines that was of great help was the vertical milling machine........not everyone has one of those to use....maybe you do !!!! It was great for squaring up metal, leaving a straight true edge and also for milling the point on the splitting wedge. To this day, 25 years later, you can still almost cut yourself on the edge !!!! Also, you have to remember that you won't save much money buy building it yourself, with the cost of all the items needed, this is an expensive venture. Steel prices are very high right now also. This forum will probably be of some help, but you should go to ArboristSite.com and pose this question there. That site is made up of people who just love cutting and burning wood. Many people on that site have built their own splitters and they are a wealth of knowledge !!!! Good luck with the splitter and please keep us updated with pictures !!!!!
MFWD
   / want to build a log splitter, need advice #9
My Build http://www.tractorbynet.com/forums/build-yourself/219145-woodsplitter-build-timberwolf-clone.html
There are many others too. I have a hyd 4way and lift on mine FYI.
I use a 5" cyl with a 22gpm pump and you cant keep up with it as one guy. 2 guys are working. My pump never really has to shift to low flow (high press) so it basically sees 22gmp all the time. Typically when working by myself, I only run the engine at 3/4 throttle to save fuel, and even then its plenty quick.
My advise, if you go with a 22gpm, step up in motor size. I have a 14hp robin on mine, and if i turn the pressure up above 2200psi, the engine will stall. The manual says 14 should work fine, but in practice I'd say 16hp minimum, maybe 18!!
   / want to build a log splitter, need advice #10
Thats odd. Does it only want to stall when you are only running 3/4 throttle??
2200psi on the HP side of only 6.5gpm and factoring only 85%eff should only require 9.8hp to do that. Odd that you are stalling a 14hp motor??
Looking at the specs, it is also odd that the iron and oak is only using an 11hp motor. cause the calculations 3000psi call for a tad over 13hp. Maybe they are only running 2500psi, or maybe the 11hp is with a 16gpm??? but even 2500psi calls for a tick over 11hp.:confused:
At any rate, something between 14hp and 18hp should be fine and should be little efficiency difference in them. But you dont need to go overboard and get a 25hp or bigger motor to drive it. Our splitter has an 11gpm pump which is 2.9gpm at max 3000psi. At 85% that calls for 6hp. We have a 6.5hp briggs and it has never even thought about stalling.
2016 AutoHauler CX11HCSD T/A Car Hauler Trailer (A56857)
2016 AutoHauler...
2013 VOLVO EC250DL EXCAVATOR (A60429)
2013 VOLVO EC250DL...
John Deere 1025R (A53317)
John Deere 1025R...
2016 KOMATSU D65PX-18 BULL DOZER (A58214)
2016 KOMATSU...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2018 Dodge Ram 3500 (A53317)
2018 Dodge Ram...
