Wand for radiator
/ Wand for radiator #21
Radiator genie user here.... really like it vs the standard type blowgun. I have one of the long tip blowgun, hangs on the wall. I think I have more control with the genie's
/ Wand for radiator #23
Many many years ago I worked in a mower shop. They had a blow gun that clipped onto a tire chuck. Dang they were handy. I've kept my eye's open but never see one to buy.
/ Wand for radiator #26
use a powerful leaf blower, HVLP & won't bend fins or perforate air filter like compressed air can sometimes do. fits perfectly onto my air filter as well to blow from inside out. reverse a funnel & use on blower tube if you want more concentrated
hey, see you have a TO35. had one for 28 yrs. they pick up sedge bloom quick. lost count of radiator blow out just like yourself. even with screen wrapped around grill. never had to blow out current tractor radiator or screen, the factory grill screen is perfectly designed for that.
after that, as rScotty suggests, just use a garden hose sprayer regards bb
/ Wand for radiator #27
/ Wand for radiator #28
Harbor freight
Quick connect to air pressure hose. Blow off dust and debris after every lawn mowing job before putting in the shed. Keep water away and keep the radiator, deck and mower dry.
/ Wand for radiator #29
Yall using air conditioning coil cleaner be careful. Some foaming cleaners have akaline or acid base.need to be rinsed thouroughly.. left on will cause corrosion
/ Wand for radiator #30
I have a radiator cleaning wand that has a blowgun with a rigid tube with several holes in the side of the tube at end of tube furthest from blowgun. An arrow marks location of side of tube that has holes & it's called an "Air Comb". My Air Comb didn't cost near the inflated price of $50 but I've had it many yrs.
The air comb is best. It will alow you to get at areas that are difficult with anything else. I have tried them all. You can do it with other tools, but not as quickly or as well.
/ Wand for radiator #31
I made my own from some copper tubing, a few fittings and an old air gun.
Doug in SW IA
I did the same with some 5/16" diameter copper tube, plugged the end, drilled some small holes and also put a rubber cap on the end so it is less likely to gouge anything. I may also added a valve to restrict the air pressure but the air gun I started with has pretty good control of the pressure. Nice thing about the copper is that it is very malleable so you can bend it if you need to and straighten it out when your done. I bought the Radiator Genie before I did this but it didn't fit very well between the stacked radiators on the LS MT3. I still use it though for cleaning off debris in more open areas and it works great for that.
2017 BOBCAT E50 EXCAVATOR (A63276)
2017 BOBCAT E50...
17601CFL (A61572)
17601CFL (A61572)
New/Unused Wolverine Quick Attach Auger (A65583)
New/Unused...
NEW 2025 Mini Skid Steer Stand On Loader (A62679)
NEW 2025 Mini Skid...
2018 FORD F-350 SUPER DUTY (A65643)
2018 FORD F-350...
36in AIM Bucket w/ Teeth Excavator Attachment (A64194)
36in AIM Bucket w/...
