wallenstein logging winches
   / wallenstein logging winches #51
Hi Everyone,
Its been of few weeks now that i ve been working with my FX85 and i love it. Lately i had a bit of issues with the clutch adjustement. Its seems like it happens when i am locking the drum and skidding my logs. The cable remains locked (even after unlocking the brake). I thought at first that it was an other issue with the remote control. but when i start adjusting the cluch via thoses 3 bolts in the back of the plate, the cable comes loose again and its all good. However, it does lock again as soon as i skid again.
Is there a trick or a proper way to know if the clutch is properly adjusted so i don t have to do it all the time?
The manual says to "feel" with the white rope engaging the rope but, again, that s for the models without the remote control.
I assume the clutch comes a bit loose when i hit a stump or when the pull as some resistance when winching.
My tractor is in the wood lot so i can t take pictures to help illustrating but i will soon.
Anyone had a bit of similar issues?
Thanks for the helps.
W.
   / wallenstein logging winches #52
The closest thing I've had to that problem (on a different brand winch with a different braking and clutch system) is when I don't wind the cable in under tension, the do a hard pull on top of those somewhat loose wraps. The tighter wrap pulls down inside the loose wraps underneath and get stuck. Sometimes it takes a lot of pulling to get it unstuck (occasionally, i need to anchor the cable to a tree and drive off to unwind it).
This also happens to be a great way to put waves or kinks in the cable, in severe cases, it can ruin the cable.
8 TOOTHED BUCKET FOR MINI EXCAVATOR (A58214)
8 TOOTHED BUCKET...
Generac XG8000E Generator (A55973)
Generac XG8000E...
2005 JOHN DEERE 160C LC EXCAVATOR (A52709)
2005 JOHN DEERE...
2006 KENWORTH T300 DAYCAB DIGGER TRUCK (A58214)
2006 KENWORTH T300...
2018 DODGE RAM 2500 (A58214)
2018 DODGE RAM...
2010 KENWORTH T800 (A58214)
2010 KENWORTH T800...
