wallenstein logging winches
   / wallenstein logging winches #41
Just use a bungy cord to hold the remote valve lever open...
SR
   / wallenstein logging winches #42
My home internet browser doesn’t allow opening above link to manual.
I imagine the remote control,(and toggle switch?..is toggle switch electric? On winch?) activates an electric solenoid that moves a hydraulic valve. Something should move that valve when you want to start stop winch.
Is it getting a voltage/signal? Is it opening closing?
   / wallenstein logging winches #43
Can you see what the green cord is tied to? Can you pull that, in opposite direction of pulling rope? Does that free cable reel?
   / wallenstein logging winches #44
The grn. rope is for the ratchet brake, holding it when you are spooling in, will lock the wire rope in place when you stop. Letting go of it, when you start spooling again, and it auto releases...
SR
   / wallenstein logging winches #45
The green rope is indeed to brake the drum. when you are ready to skid the logs for example. not in use when you are winching in as you would either be using the remote , away from the tractor (which is what i am having issue with) or pulling the white rope, for models without remote control.
   / wallenstein logging winches #46
Oops - "Self-releasing", not self-relaxing. I'm guessing I dictated that one. For some reason, it won;t let me edit the post, even though it just went up yesterday.
Well, for that matter, I can't justify a $3000 logging winch on my tractor.
My biggest use of a self-releasing snatch block isn't to "pull trees sideways" at most 4' (for example to get it round a stump. It's when I need to pull a tree around a dogleg on it's path out of the forest. The areas in which I work are dense enough that I can't always get a straight-line pull. With a self-releasing snatch block, I don't have to clear a straight path to every tree, and I don't have to be constantly walking back and forth to release a block or slider. I have 230' of cable on my winch. Often when thinning in an area, I'll set the tractor and the cable stretches out 50-100 feet to the area where I'm thinning. it then takes a turn at the block , going another 50-100 feet in a variety of directions to reach the trees I'm pulling out of that area. It also makes it easier to protect nice sawlogs or veneer-quality logs which I am not ready to harvest when I'm pulling out firewood. It saves me a lot of time, increasing productivity and minimizing impact on the residual stand.
I have been known to take a bend around an old stump, but that requires going back to flip the cable off the stump once I've pulled the log to it. I prefer not to use sliders to redirect, unless it's a very small angle, since taking a significant bend around a slider is hard on the cable.
I'm not saying a snatch block is for everyone. We all have our own trade-offs for time, efficiency, and cost, and our own preferred ways of working.
If you are handy with metal-working, this old article about snatchblock winching tips includes information about making your own self-releasing snatch block. I almost made one myself, but when I machinist on another forum started selling nice ones for $180, I bought one of those for my second block instead. (He since has stopped selling them.)
I think your the only one who noticed that, now you pointed it out it sticks out like a sore thumb, I do a lot of self-relaxing, I'm doing that right now..... IMO I'm quite sure in 20 years at only 5 cord/year one could easily justify $4000.00 on a pto winch, not to mention it save's the cost of doing things the hard way which sometimes is the wrong way which could end up hurting one's back....... I'd rather save myself $300.00 and tell the dog to get the heck out of the way so I wont hit his leg......Where's the article you mention, sounds interesting and self-relaxing?
   / wallenstein logging winches #47
Wouldn't this green rope remote control winch problem be easier to understand with pictures, I have a weak imagination................
   / wallenstein logging winches #48
Oops. I guess it would help if I included the article. Here it is. Some tips on using a snatch block and a sidebar about making one. (I also edited the original post to include it there.)
   / wallenstein logging winches #49
Mystery solved! The issue was indeed the lever control for the hydraulics. It has to remain pushed forward to keep the hydraulic flow open in order to work. I also had the 2 rear hydraulics hoses plugged into each other spot so i swith them over . I had the lever kept in place, as adviced, with a little bungee cord. It does the trick for now until i get the detent valve and a second lever so all can be used properly without need of bungee cord.
I will update with pictures soon to illustrate the whole thing. Now I can t wait to see it in action at work!
Thanks everyone for the help here, I ll post some pics of the ongoing result of it all!
w
   / wallenstein logging winches #50
I like herring solved problems, coarse I wouldn't of figured that out but that might help someone else down the road.
2014 VOLVO VNL DAYCAB (A58214)
2014 VOLVO VNL...
Electric Diesel Fuel Pump with Hose Reel (A55851)
Electric Diesel...
2010 Chevrolet Traverse SUV (A56859)
2010 Chevrolet...
19088 (A55758)
19088 (A55758)
CAT D5G LGP DOZER (A58214)
CAT D5G LGP DOZER...
2019 PJ TRAILER 32FT GOOSENECK (A58214)
2019 PJ TRAILER...
