Voltage Regulator
/ Voltage Regulator #1
rockyridgefarm
Elite Member
NEOklahoma
Yanmar YT347
my 186D regulator light is usually lit. It flickers some. I was told it is almost certainly not a defective regulator, because they are very expensive (honest, that is was what the JD parts guy said...) Where should I look, or is there even a problem. I have not noticed any actual problems, like lights flickering, etc.
/ Voltage Regulator #2
Mike, if you don't have a volt/ohm meter, you need to get one, (they start at about $10), and check your alternator output at the battery terminals. You should see about +14.5 volts dc at a fast idle. If around 30 volts, bad regulator. If no output, only battery voltage, could be reg. or alt. Unhook regulator and briefly check alternator. If no output, bad alternator. Should see the 30 volts. If no prob., probably bad light. Of course make sure belt and all connections are tight.
/ Voltage Regulator
Thanks, I think my Fluke will work, I'll check it out
/ Voltage Regulator #4
They may want to check the connections at the light.
soundguy
/ Voltage Regulator #5
If you got a Fluke then you probably know all that stuff. They're the best. Mine is a 30 year old Fluke 8020A Multimeter.
1999 Sterling L7501 Dump Truck, VIN # 2FZHRLLB5XAA64093 (A61165)
1999 Sterling...
2015 FREIGHTLINER M2 106 T/A 6X4 FLATBED WITH MOFFET (A59909)
2015 FREIGHTLINER...
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2020 CHEVROLET...
UNUSED WOLVERINE TR-26-01C 3PT QUICK HITCH (A62131)
UNUSED WOLVERINE...
PALLET OF ASSORTED PIECES OF MARBLE COUNTERTOP (A62131)
PALLET OF ASSORTED...
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2020 CHEVROLET...
