voltage regulator for 1700
/ voltage regulator for 1700 #1
fig
Thomasville, NC
yanmar 1700
Guys,
Has been a long time since I have posted, but having problems.
Took alternator off and had tested at Advance Auto. They said it was bad and could not cross over. Took it to a rebuild shop and said it was charging fine.
I searched here and found a thread that said to use a '72 Datsun 510 regulator that it is a direct replacement. Well I got the regulator in today and it is a 5 post not 6 which is on my 1700.
Can someone tell me what is the replacement.
Thanks,
Newton
/ voltage regulator for 1700 #2
I think I have two in the Shop ,If I do I will PM you and you can give me your address and I will send you one.I will look in the morning .
Gizmo
Thanks! Let me know.
Newton
/ voltage regulator for 1700 #4
I did not find it,My son has a motor a part in the shop he has moved ever thing .He will be back from Georgia tomorrow I will see if he knows were it is.mind was not bad just lost a ground.
/ voltage regulator for 1700 #5
I would Just buy the correct one from a dealer here and be done with it
(INOP) 2018 BOMAG BMP8500 TRENCH COMPACTOR (A60429)
(INOP) 2018 BOMAG...
New/Unused CFG Industrial H12R Mini Excavator (A65579)
New/Unused CFG...
KOMATSU PC88MR-11 EXCAVATOR (A64279)
KOMATSU PC88MR-11...
2021 BOBCAT E50 R2 SERIES EXCAVATOR (A63276)
2021 BOBCAT E50 R2...
2011 Freightliner M2 106 Chip/Dump Truck, VIN # 1FVACWDU7BDAU8870 (A65563)
2011 Freightliner...
2007 Peterbilt with a CAT Engine (A62679)
2007 Peterbilt...
