Vine hooked on bush hog...
/ Vine hooked on bush hog... #1
RMEADOWS
Lakeland, Fl
MF 1428
I'm clearing land using my bush hog. I was backing into an area, squeezing the hog through two close trees, no problem. I pulled forward and had a 1.5" thick vine hooked on the wheel on the bush hog.
This caused me to do the highest tractor wheelie of my life. The only thing that saved me was the bush hog acting as a wheelie bar. I hit the clutch and bounced that front end..
Did I do something wrong or was it bad luck?
/ Vine hooked on bush hog... #2
Anything you pull behind the tractor that is NOT hooked to the real drawbar will result in a "wheelie" if the tractor gets enough of a grip with the rear tires. Many a tractor came the whole way up and over when someone unaware of this tendency wrapped a chain around the rear axle to yank something that really didn't want to move.
I said "real drawbar" to differentiate between it and the ones you can get at TSC that go between the 3PH arms. The 3PH arms just hinge up under a hard pull that lifts the front of the tractor.
Glad you got it under control..............chim
/ Vine hooked on bush hog... #3
Is that a pic of a K 245? I used to have a 245DT, boy do I miss it.
Beware, you can lift the front wheels even when pulling from the ridged drawbar.
/ Vine hooked on bush hog... #4
I never thought vegetation was strong enough to cause suchhavoc!! thanks for sharing ..Raybee
/ Vine hooked on bush hog... #5
Has anyone ever made a wheelie bar for there tractor?
I thought about it, but it seems there's no place for a heavy dute mounting point.
Yes, I have a L245. Great ittle tractor, very light frnt end!
2016 Volvo VNL T/A Sleeper Cab Truck Tractor (A61573)
2016 Volvo VNL T/A...
Challenger 65D/75D/85D Tractor Parts and Service Manuals (A63117)
Challenger...
2024 Ford Explorer SUV (A61574)
2024 Ford Explorer...
2018 Bomag BC572 Articulated Refuse Compactor (A61572)
2018 Bomag BC572...
Wilson AGH-500 (A64119)
Wilson AGH-500...
2016 MULTIQUIP DCA-25SS1U4F PORTABLE GENERATOR (A63276)
2016 MULTIQUIP...
