MossRoad
Super Moderator
- Joined
- Aug 31, 2001
- Messages
- 65,912
- Location
- South Bend, Indiana (near)
- Tractor
- Power Trac PT425 2001 Model Year
Folks, after a couple of hours blowing snow yesterday I decided to unattached the thrower and attach the sweeper. The 1/4 quick connectors came off easily. But I could not re-connect the QA coupler -- it just would not connect. My neighbor dropped by and he could not connect it either. We tried all the techniques discussed in the thread to no avail. To be brief, the next day we were finally able to connect it only by one person holding down the Aux handle while the other pushed the connector on. That is a new technique that I could never do by myself. Frustrating! I did try the tap tap method to relieve the pressure in the hoses. Cycling the Aux level did not seem to work.
Below are some photos of the couplers.
Before I knew about the punch and tap method, I had the same problem once trying to reconnect the QA. I took an open end wrench and cracked the fitting at the QA cylinder until a couple drops of oil came out. Then it was easy to reconnect it. I posted my problem here on TBN and that's when someone, Bird, I believe, told me about the punch, rag and rap with a hammer. That method I've used maybe twice and it worked well both times.
