Videos of New PT425 Arriving/Unloading
   / Videos of New PT425 Arriving/Unloading #101
There are some things you might be able to do to cut down on the number of times you have problems besides all of the suggestions we have already mentioned.
One possibility would be to Tee off your auxillary pto supply and return and add hydraulic ball valves. That way you could keep your disconnect always hooked up and just close those ball valves and open the other set when you want to use the auxillary circuit. Even better would be a manual selector valve (cheaper probably too).
A nicer mod would be to so what I am doing and add solenoid selector valves to the lift and tilt circuit. Then the auxillary can be used just for the quick attach and you can use the joystick and a button for everything else.
Besides $, space is a problem with these suggestions. The valves and associated hoses take up space.
It also would not be too hard to have two notched metal plates, sliding each over a connector with threaded studs or bolts on each side of the connector to pull the two plates together. You could use a battery drill or keep a gear wrench style wrench on the tractor.
But following all of the suggestions made here including holding the handle up and down with a bungee has made a huge difference for me in making these connections.
Ken
   / Videos of New PT425 Arriving/Unloading #102
Preaching to the choir:
It doesn't take much temperature change to create an awkward pressure differential. The QD's are designed to be connected at zero pressure differential. As long as the ambient temperature, hydraulic temperature, and radiant temperatures are about the same as when they were disconnected, connecting the hoses is easy.
BUT:
If you disconnect with hot oil on a cold day...
Or hot sun on hoses that were disconnected while cold...
Or about a zillion combinations of temperature and pressure...
You will get a lesson on thermal expansion and the incompressability of fluids.
I'm used to connecting and disconnecting air tool hoses at about 120 psi. I thought I knew quick disconnects.
Wrong.
Air pressure changes slightly with temperature. Air is quite compressible. That's why there are lots of air springs. I can squeeze a 120psi air connector without thinking about it (except for the noise when it pops).
Oil changes pressure all out of proportion with our perception of air temperature. I haven't seen a lot of hydraulic springs. Air squishes a whole lot better than oil.
Fingers don't squeeze oil very well - especially when they hurt.
I can connect an air hose at 15*F and disconnect it at 150*F with no problem, or vice-versa.
I can't do that with hydraulic hoses. That stuff just doesn't give.
And that's all I've got to say about that.
   / Videos of New PT425 Arriving/Unloading #103
We used to be told that you cannot compress a liquid. While we know that you can compress a liquid, it takes a great deal of pressure to compress it just a tiny, tiny bit. That's why when we hit the quick connector with a punch and hammer, only a drop or two of oil comes out, yet all of the pressure is relieved.
I'd say, just smack it one good rap with a hammer and that should do it.
   / Videos of New PT425 Arriving/Unloading #104
Clumber,
This is probably a dumb question. Your not trying to just push these connectors together without also pulling the spring loaded locking ring back are you?
sg
Clumber,
sg
Yes, I am pulling back the locking ring.
   / Videos of New PT425 Arriving/Unloading #106
On my Safeway hyd QD's, which are equal to Fasters QD's, you can either push or pull the sleeve. Pushing the sleeve while connecting is much easier. I would highly recommend these QD's.
These QD's allow one-hand push-to-connect operation.
   / Videos of New PT425 Arriving/Unloading #107
I don't know if this has been mentioned, but have you by any chance had dirt on the male connectors or connector and tried to hook it up. You may have done this without even paying attention [happens to all of us at some time], but any way when you tried to hook it up maybe dirt has got behind the little bearings in the female part of the coupling and that little bit of dirt is holding you off.
The part of the coupling that pulls back has a small groove in it that lets the bearings drop back in it and that will allow the coupling to connect. If there is a little bit of trash of some kind in that groove that could be your problem.
I believe you are trying to hook up a snow thrower, is it a hydraulic motor that your are trying to hook up or is it the quick attach circuit? I was just curious.
I am going to try to describe something that I don't know if I can, but here goes anyway. You know when you are pulling a cork out of a bottle, you rock the cork back and forth but hold the bottle still or rock the bottle in the opposite direction, well those fittings are close fitting but sometimes you can do a little of that type rocking to help get it to slide up on or in the fitting. I surely hope this helps, if not I'll keep thinking. You might have to get some kind of mechanical device made up that will help you to seat the couplings, but there is a risk of damaging the coupling that way. If there is dirt in the male coupling that is holding you off you might be able to flush it out with wd40 using the straw and spraying back in the female coupling with the ring pulled back, spraying directly on those little bearings.
   / Videos of New PT425 Arriving/Unloading #108
Gentlemen
I just purchased my PT 425 at the same time as Clumber and it is my disctinct impression that these QD's couplings are not of stellar quality. Mine are made in Italy, and I am wondering if they are made by FIAT :laughing:
They are not even close to the high quality units made in this country the JJ refers to and that I have used over the last 30 years. My suggestion is to regroup and buy some from Surplus Sales or local hydraulic supplier and advance to a new state of wonderfulness in your quick:thumbsup: coupling activities
   / Videos of New PT425 Arriving/Unloading #109
It is probably time to start a new thread, as it has drifted away from the videos of a new Power-Trac.
   / Videos of New PT425 Arriving/Unloading #110
Gentlemen
Well, I kinda have to disagree with that. I have the same Italian quick connects on my PT425 that is 10 years old. They seem to work fine. Unless they changed something over the years, of course.
2019 Land Rover Range Rover Sport AWD SUV (A55853)
2019 Land Rover...
Club Car Intellitrak Golf Cart (A57453)
Club Car...
2026 14 ft Quality Steel 7 Ton T/A Dump Trailer (A56858)
2026 14 ft Quality...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55852)
2006 iDrive...
2011 INTERNATIONAL WORKSTAR 7400 SBA 6X4 DUMP TRK (A52706)
2011 INTERNATIONAL...
2019 Kaufman Pro Series Car Hauler Trailer, VIN # 5VGFE4736KL004723 (A57453)
2019 Kaufman Pro...
