Verticle Motor on Log Splitter
/ Verticle Motor on Log Splitter #1
tnau664
Piedmont, AL
Massey 231S
Hey shop guys. Need help for a question brought up on the Lawn and Garden forum. I want to add electric start to my splitter so my dear one can help with the firewood. There was an older post that discussed the use of a hydraulic pump on a verticle shaft motor rather than the typical horizontal shaft. Has anyone seen this done? I think simple thoughts, but seems like it should work.
Thanks
T
/ Verticle Motor on Log Splitter #2
Yeah, lots of splitters have vertical shaft engines. The hydraulic pump couldn't care less about it.
/ Verticle Motor on Log Splitter #3
It will work. I assembled a Barnes 16gpm 2 stage pump tp the bottom of a B-S 11.5 hp motor and has worked fine for 8 years. You'll need the adapter that's used for horizontal engines and the appropriate lovejoy connectors for pump and engine shaft. I used the motor mount plate from the donor riding mower and welded brackets to it which centered the pump adapter to engine.
Thanks for the reply. Now to confiscate a mower. What do you mean by "the adapter that's used for horizontal mowers"? I have the lovejoy connector, but no other adapter.
The idea of using the mounting plate for the motor is great. I'll look at using it with the under hood tank and just put the hood back on to protect it all.
Thanks again
T
/ Verticle Motor on Log Splitter #5
Thanks again
T
Just be sure to mount the tank high enough so the pump cannot be run dry. It only takes a little of that to ruin a pump.
Harry K
2018 JOHN DEERE 650K LGP CRAWLER DOZER (A65053)
2018 JOHN DEERE...
KUBOTA KX033-4 EXCAVATOR (A65053)
KUBOTA KX033-4...
2018 Kenworth T880 Quad Dump (A62613)
2018 Kenworth T880...
2021 KMC 7406 (A64126)
2023 Takeuchi TL6R Compact Track Loader Skid Steer w Low Hours (A63689)
2023 Takeuchi TL6R...
2014 Bobcat T870 (A64126)
2014 Bobcat T870...
