s219
Super Member
- Joined
- Dec 7, 2011
- Messages
- 8,607
- Location
- Virginia USA
- Tractor
- Kubota L3200, Deere X380, Kubota RTV-X
Are you speaking from past experience smoking with this particular model smoker? It is double walled one would believe it would hold the heat in cold weather.
Yes, I speak from experience. It's not so much the insulation as the raw amount of BTUs -- just not enough heat input for cold weather. And it doesn't matter if it's a gas unit or an electric, since you've got the equivalent of a one-burner grill (or less) either way. Generally I have to run about 3X to 4X the heat input to smoke stuff in the winter.
Keep an eye on the temperature as you head into cooler weather -- once it starts having problems keeping up then change your cooking technique, look for an alternative, or wait for warm weather. Nothing can ruin a nice piece of meat more than a cool cooking temperature. Pork cooked to 145-150F is perfect for slicing and carving. For pulling it needs to be at least 220F and is best at 250F (fall off the bone). In between, from about 155F-210F is a zone where the meat is just not going to be good eating -- too tough and stringy. Avoid that temperature zone!!
